586,106 active members*
3,047 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Step file 3D Milling
Results 1 to 6 of 6
    Dec 2010
    Hello.
    I got a step file, and would like to mill the S part you can see in the picture. My problem is that every time I calculate the tool-path I get the tool-path that is not smooth and has some bigger mistakes (in the picture in red circles).
    I tried to do the job with a 2.5mm tool with 1.25mm corner radius using Z level rough, 0.1 depth of cut, 1mm step-over.
    Picture:
    Uploaded with ImageShack.us
    Here you can download the bobcad file I made with tool-paths:
    http://www.4shared.com/file/g5xXmNpO/Bcadfile.html
    And here is the original step file:
    http://www.4shared.com/file/Y9m7Gac9/originalstep.html
    Hope the links work?
    (Updated the links, do they work now?)
    Is there an error in step file geometry, problem on bobcad side, or on my side (choosing the correct parameters?).
    Any help will be appreciated.
    Oct 2006
    173
    The links here seem to be broken , If you re-post the file I will take a look at it.
    Dec 2010
    I have repost the file.
    Oct 2006
    173
    Found two things that may be the issue..
    1. The machining tolerance.
    0.0127 Try increasing the resolution of the tolerance.
    Right click Milling tools choose current settings then choose Machine Parameters.
    Set the tolerance to .001 see if the result is better.
    2. Try using the advanced rough instead , If the issue is The tool path / Bobcad the advanced roughing will do the same type of cut but uses a different algorithm.
    Dec 2010
    Thank you for your answer.
    Setting tolerance to .001 helped. The path is now much better!
    There are still 3 dots in the tool path. I will try to increase the resolution of the tolerance even more. What would be appropriate resolution to get really smooth tool paths?
    Are there any other tolerances important for machining, that I should be aware of?
    Oct 2006
    173
    No , Just there. The tolerance may need changed on a part by part basis , according to size of part I would suggest .0001 no smaller unless your making very small parts.
  1. Replies: 1
    Last Post: 07-04-2011, 03:08 PM
  2. step file into bobcad 21 then into autocad 2000?
    By metlcutr55 in forum BobCad-Cam
    Last Post: 07-17-2009, 12:25 AM
  3. step file
    By ataxy in forum Mastercam
    Last Post: 10-14-2008, 03:31 PM
  4. How to edit MPFAN post file step by step
    By m_bhui in forum Post Processors for MC
    Last Post: 10-04-2008, 11:42 AM
  5. Step when milling arcs
    By dpkozi in forum MetalWork Discussion
    Last Post: 01-30-2008, 02:18 PM
