586,391 active members*
3,024 visitors online*
IndustryArena Forum > CAM Software > EnRoute > feed rate % rpm
    Aug 2008
    63
    feed rate % rpm
    hello
    good morning
    thanks for replying and sharing
    I have a question for you
    I want to make a sample
    a 3D texture
    I have a multicam 3000
    sample is 4x8ft
    and I have a bit Onsrud 52-280 of 1 / 4
    I have no experience in this type of cuts
    I can advise that speed and rpm parameters I can use
    Jun 2010
    463
    feed rate % rpm
    To create a 3-D texture you are going to have to change your bit to a ball nose bit, second what type of material are you going to be cutting for this sample texture.
  1. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 11:14 AM
  2. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  3. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
  4. C & Z Feed rate
    By rfstar in forum G-Code Programing
    Last Post: 06-22-2005, 06:38 AM
  5. How can I up my feed rate ?
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-13-2004, 03:40 AM
