Originally Posted by
07BlackOps
.... And then what about doing a tapered thread, do I need tell the control to follow the taper....
Yes but you don't use explicit start and end points. The threading canned cycles G76 and G92 use an I value in the canned cycle definition line to specify the taper between the start point and end point of the thread. This value is normally a radius measure which differs from other canned cycles such as G71 where you program the taper using diameter measure.
As txcncman says you are going to have to develop the attention span to read through training material. I will agree it is not easy but it is necessary. And don't get too discouraged if things do not seem to make sense the first two, three, four, ? times you read them. Eventually things will start falling into place.
