586,062 active members*
4,818 visitors online*
Results 1 to 3 of 3
    Coroplast plastic cutting machine
    Coroplast plastic cutting machine can make operations to coroplast plastic like cutting, half cutting, folding line making, dotted line cutting, line plotting and writing.
    Functions of coroplast plastic cutting machine:
    ◇It can cut many different materials (such as coroplast, pp sheet plate, rey board, gasket, leather, etc.)
    ◇It can half cut ,whole cut, crease and dotted line.
    ◇Using laser lamp improve location precision
    ◇Using for sample maker or small batch of production.
    Specifications of coroplast plastic cutting machine:
    The most popular sizes are (mm) 2500*1600, 1700*1300, and 1300*1100. Other sizes are available upon customers’ requirement. The maximum cutting size is 3500*2000.
    Configuration Oscillating blade, pen, creasing wheel, drag knife
    Max speed 1350mm/s
    Smallest cutting diameter 6mm
    Maximum cutting thickness 15mm
    Control line and driver Servo
    Precision ≤0.1mm
    vacuum 5.5kw
    Data form HPGL
    Voltage 220v±10% 50Hz
    Data port PCI port
    Data Transmission speed 10MB/S
    Input cushion area 32MB
    CNC cutting machine-www.cutcnccam.com- pls contact [email protected]
    CUTCNC Guest
    The coroplastic sign make by our cutter plotter
    Nov 2018
    Cutting a corrugated plastic sheet (coroplast sheet) is very easy, but the thickness of the coroplast sheet is variable. If the thickness is greater than 6 mm, cutting with a utility knife will increase the difficulty. https://corrugatedplasticsheet.net/m...lastic-sheets/ Here you can get any information you want about coroplast sheet.
  1. Replies: 3
    Last Post: 09-19-2010, 02:40 PM
  2. Replies: 0
    Last Post: 09-17-2010, 09:09 AM
  3. Replies: 0
    Last Post: 09-17-2010, 08:51 AM
  4. Need help with coroplast
    By moldman in forum Material Machining Solutions
    Last Post: 11-08-2008, 08:10 PM
  5. CNC plastic cutting help!
    By woox in forum Glass, Plastic and Stone
    Last Post: 08-28-2008, 08:54 PM
