586,308 active members*
3,695 visitors online*
    Aug 2006
    129
    Undo limitations
    It seems somethings just can't be undone. Once a mate has been confirmed and it borks the geometry it can't be undone. Just what are the limitations? Is there a list or a section in the manual that outlines just what is undo-able?
    Dec 2009
    458
    In my very limited time working with this software I've found that I can only "undo" something once.
    If I happen to go two or three more steps beyond the certain change I've decided to "undo," it just can't be done. (at least not by me)
    In a case like this, I'm still trying to figure out how to just delete or remove that particular section of my sketch/drawing that I would have "undone" if I could have.
    Then I could re-do just that piece of the drawing without having to start over from scratch.
    I'm sure you can you tell from my reply, just how new of a newbie I am.
    MetalShavings
    Dec 2009
    458
    OK, I think I figured it out.
    I was using the "undo" command via the Edit scroll down menu. It's the reverse pointing circular arrow at the upper right of the standard menu bar that does the trick.
    I can see that this learning curve has a much steeper grade than I was hoping for but, even still, I'm making progress.
    MetalShavings
  1. Undo work not correctly in BCC V24
    By Questionguy in forum BobCad-Cam
    Last Post: 02-13-2011, 04:12 AM
  2. Autocad 2011-undo & redo zoom
    By Patternboy in forum Autodesk
    Last Post: 11-04-2010, 01:20 PM
  3. CNMG 432 DOC Limitations
    By premier_industr in forum MetalWork Discussion
    Last Post: 09-07-2008, 03:25 PM
  4. Why surfcam doesn't have UNDO feature?
    By qmas99 in forum Surfcam
    Last Post: 04-17-2007, 02:45 AM
  5. Really, only one undo!
    By MikeA in forum Mastercam
    Last Post: 09-27-2003, 03:23 PM
