586,103 active members*
3,794 visitors online*
Results 1 to 9 of 9
    Sep 2005
    1660
    VSD-A Disable Pin
    Ok so.. I've been running these VSD-A drives for longer than i want to admit w/ out some of the wiring completed. I've finally got time and the hardware to wire this all correctly but now I'm confused on the 'how' part of the equation..
    In regards to the CMD header Pin 4 [Disable + ] should I be putting +5vdc in here to 'enable' the drive? If at some point we want to disable the drive we would remove the 5vdc?
    Or
    Is this a '5vdc to pin4 to Disable the drive' functionality?
    I would think the 5vdc to ENABLE the drive is a safer way of wiring things but... maybe I'm missing something.. [ie if a wire breaks or a P/S goes south, the drive will disable and then not following commanded position and fault?]
    JerryFlyGuy
    The more I know... the more I realize I don't
    24221
    From a look at the manual it is both connections to an Opto input en-/en+ which means you could set it for sink or source type, the example shows it in sink mode, the en- is connected to common, and the +ve is taken High, presumably taking it high (+ve) will disable if it is working now with it open.
    Al.
    Albert E.
    Sep 2005
    1660
    Al is that on the VSD-E or the VSD-A?
    JerryFlyGuy
    24221
    VSD-A, listed under Legacy Drives?
    p9/19.
    Al.
    Albert E.
    Sep 2005
    1660
    ahh I see what your looking at. Ya I think it is disabled when Disable + is taken High... which is not the best but..
    So on my illuminted push button 'Enable' switch, the switch is open and the light is illuminated. [Instead of being illuminated when the switch is closed]... kinda backwards...
    JerryFlyGuy
    24221
    If you have it unconnected right now and the drives are on then it has to be high to disable, with the en- at common.
    You could always either change the logic to the lamp or add a N.O. switch section to the PB?
    Al.
    Albert E.
    Sep 2005
    1660
    Possibly but both of those options are probably outside my skill-set.
    JerryFlyGuy
    Sep 2004
    1207
    To set VSD-A in disabled state (and also clear fault status), connect CMD pin to 3 GND pin 4 to 5V.
    In VSD-A the polarity is fixed (so that drive is enabled by default) and in VSD-E/XE the enable/disable pin polarity can be chosen via GDtool.
    Sep 2005
    1660
    Thanks Tero, I may be picking up a couple more [VSD-E] drives but for now I'll wire the VDS-A's as you've noted.
    Thanks sir!
    JerryFlyGuy
  1. VSD-E disable and recovery
    By jnnewton in forum CNC Machine Related Electronics
    Last Post: 09-01-2014, 11:34 AM
  2. How do you disable SMI?
    By CROSSHATCH in forum LinuxCNC (formerly EMC2)
    Last Post: 03-04-2009, 10:22 PM
  3. How to disable ac97sound?
    By Mr Bits in forum LinuxCNC (formerly EMC2)
    Last Post: 05-01-2008, 11:25 PM
  4. Disable FAPT F3T
    By Pxt in forum Fanuc
    Last Post: 02-28-2008, 03:28 AM
  5. Disable with Mach
    By belli in forum Mach Plasma / Laser
    Last Post: 07-14-2007, 09:53 PM
