586,100 active members*
2,615 visitors online*
IndustryArena Forum > Community Club House > Cutting thin parts
    Dec 2010
    16
    Cutting thin parts
    Newbee- Cutting sm. parts from aprox. 12x16in. x 1/8in.thick, plastic and alum. plate. on an XMX2. Supporting 1/8in.plate stock with cornor screws, get lots of vibration because stock is not supported throughout. Vac. table is to costly for what I am doing. Need some way to temporaily stick the plate to pressed board mounted to the table. I was thinking of two sided contact paper or tape? Is there a better way? Thanks for your thoughts.
    cnccleve
    Jun 2007
    3757
    You can glue it to with PVA glue or shellac.
    PVA glue will dissolve with water.
    Shellac will dissolve with methylated spirits or alcohol.
    Double sided tape, if it is strong enough.
    Feb 2007
    532
    Double sided tape has worked well for me, but it would start to add up in cost if you're cutting a lot of bits.
    Sep 2008
    51
    You could try a right-hand cutting, left-hand helix end-mill.
    Cuts the same way as normal, but helix will push the part down,
    rather than pull up like a regular end mill would. Works best if part
    is supported by a fixture plate.
    Good luck!
  1. Cutting Thin Foam (Depron) please help!
    By adbradley in forum CNC Wire Foam Cutter Machines
    Last Post: 12-18-2008, 10:02 AM
  2. What to use when cutting thin materials ?
    By twocik in forum Benchtop Machines
    Last Post: 04-07-2008, 09:49 PM
  3. cutting thin metal
    By clittle in forum MetalWork Discussion
    Last Post: 09-05-2007, 10:27 PM
  4. RFQ - Cutting Thin Plastic Sheet
    By ukchris in forum Employment Opportunity
    Last Post: 12-07-2006, 03:16 AM
  5. Cutting thin aluminum
    By neonguy in forum Waterjet General Topics
    Last Post: 10-13-2006, 02:29 PM
