587,003 active members*
2,802 visitors online*
Page 33 of 33 23313233
Results 641 to 645 of 645
  1. #641
    Mar 2014
    735
    Re: Big Bamboo - New Machine Project Started
    You make some incredible stuff Jerry! I'm really intrigued by the kinetic art table.
  2. #642
    Aug 2011
    999
    Quote Originally Posted by pippin88 View Post
    Are you still happy with the dust setup drawing past the spindle? EDIT: I see you changed it a little later, but the principle is still the same - dust hose to above spindle, then a duct around the spindle.
    Thinking of similar
    Absolutely! The air-cooled "water-cooled spindle" still works perfectly after 8 (or is it 10?) years or so. Barely gets warm even with bigger bits and at high feed rate. No water hoses, reservoir, pump, radiator, fouling, leaks whatsoever. No noisy air-cooling fan other than the dust collector that I need anyway.
    I was tempted to improve the dust shoe at the bottom of the conduit because depending on the part to be cut it does allow larger chips to escape. But then, so far I was too lazy and it is not so bad. At least the fine dust is completely collected.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
  3. #643
    Aug 2011
    999
    Here is my latest project, made on the BigBamboo machine. I have been fascinated by marble machines for a long time, especially the ones that can count time like the "Idle Tyme" marble clocks of the 70's. Most such machines are complicated 3-dimensional assemblies made from many individual parts.
    For this project I set out to design a much-simplified marble machine clock with fewer parts that is essentially 2-dimensional and optimized for CNC machining. Unfortunately, the clock is not really suitable for a living room because it makes quite a racket while operating.
    A video of the operation (better open the video in Youtube to get the high resolution version):
    Attached there are pictures of the completed machine, close-up of the seconds "hands", the back side, machining the base plate and the bearing brackets.
    Took a while to design and test the functions. Actually, this is the 4th version that finally worked reliably...
  4. #644
    Jun 2023
    136
    SORRY, I CAN'T USE YOUTUB IN CHINA.
    Can you email me a video or photo?
    If you need mineral castings.You can contact me,I'm from China,My company has produced a lot of products, small can reach 100KG, large can do 46 tons.Linear motors
  5. #645
    Aug 2011
    999
    Wow...another 2 years since my last post. But anyway, my BigBamboo machine is still going strong. After 12 years total, I guess the build was worthwhile.
    I am still doing projects that seem unique (to me at least) and often supported with specialized software that I write for the intended purpose.
    My last software project is a tool to generate tool paths for flat machined dovetail and finger joints. These can be standard (perpendicular) or have compound angles, be half blind or pocketed and can do an inlayed joint as well. Looking good so far and I will publish it to my freeware collection probably in a few weeks.
    Here are some pictures of a 5-sided box with finger joints and walls that are slanted 30 degrees from vertical. The pattern on the lid is a vcarve inlay made with Vectric software (demon-proof design with pentagram and horus eyes ) .
    Attachment 503524
    Attachment 503526
    Attachment 503528
    Attachment 503530
    Other joint types are possible as well, but I still need to do a real project:
    Attachment 503532Attachment 503534
  6. #646
    Aug 2011
    999
    Quote Originally Posted by JerryBurks View Post
    .....My last software project is a tool to generate tool paths for flat machined dovetail and finger joints. These can be standard (perpendicular) or have compound angles, be half blind or pocketed and can do an inlayed joint as well. Looking good so far and I will publish it to my freeware collection probably in a few weeks....
    Ahem, that would be NOW.
    You can download this (and several other freeware pieces) here: https://fabrikisto.com/tailmaker-software/
    Joe Federer, the owner of this web site is generously hosting my files and in case of questions, please don't write to him but contact me directly: [puzzlejoint] {at} /outlook/ (dot) \com\
    In the meantime I finished another project using this software. It is claro walnut with maple inlaid joints and lid ornament.
    Attachment 503968
    Attachment 503970
    Attachment 503972
    Attachment 503974
    Attachment 503976
    Attachment 503978
    Attachment 503980
  7. #647
    Jul 2018
    6447
    Hi Jerry - They are beautiful things. Peter
  8. #648
    Feb 2016
    286
    Wow that's some serious joinery!
  1. 7 x 10 project started
    By blades in forum Mini Lathe
    Last Post: 01-25-2017, 05:27 AM
  2. CNC Project Started
    By NotSqueaky in forum CNC Wood Router Project Log
    Last Post: 09-10-2014, 12:41 AM
  3. New Project Started
    By Rumblebelly5 in forum Joes CNC Model 2006
    Last Post: 09-15-2012, 10:50 PM
  4. My 4x8 project has started
    By MetalHead6263 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-31-2012, 07:30 AM
  5. Started new project
    By rustamd in forum DIY CNC Router Table Machines
    Last Post: 05-31-2009, 04:12 AM
