587,129 active members*
3,037 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Need custom foam machining tooling
    Jul 2004
    103
    I need a source for cutters to machine polyurethane foam. I need:
    - 1/2" end mill that will cut 6" deep
    - 1" dia ball end mill
    - 10.7 degree tapered end mill that will cut 2 3/4" deep
    Any ideas where I can buy these. Machining foam shouldn't put much load on the cutter... Are there special cutters for foam?
    Thanks for any help.
    Terry
    May 2010
    307
    Streamline Automation has some custom foam cutters that looks like they might fit what you are looking for.
    Foam Cutting Tools | Foam Router Bits | FROGTools
    Jul 2004
    103
    Great! Much appreciated.
  1. Custom Foam Inserts?
    By mabmojo in forum CNC Wire Foam Cutter Machines
    Last Post: 04-12-2010, 07:21 PM
  2. MIS CNC Machining and tooling - General machining - Thermoform Molds
    By modernprecision in forum Employment Opportunity
    Last Post: 11-24-2007, 05:05 AM
  3. Custom Tooling Plate
    By Swisha_House in forum Benchtop Machines
    Last Post: 11-12-2007, 09:33 AM
  4. I'm looking for someone to cut and coat custom foam parts
    By decor designer in forum RFQ Feedback
    Last Post: 08-21-2006, 11:44 PM
  5. custom tooling
    By CNC Pro in forum OneCNC
    Last Post: 04-11-2003, 04:36 PM
