586,077 active members*
3,911 visitors online*
    May 2007
    54
    electronics enclosure
    has anyone managed to get all the electronics ( power supply, stepper/servo drivers, spindle control, breakout boards etc ) into a single box mounted directly on the rear of a X2 size machine? I am also thinking of integrating the PC ( ITX motherboard ) into the case? pros cons?
    Dec 2007
    2134
    It would be easily do-able, but given the fairly large current draw and cabling, you'd need to ensure there's really, really, good shielding (lots of metal mesh and star earthing) on all the parts of the control box, which also would ideally be metal, not plastic. The heat would be the next consideration with keeping dust and waste from inside it, while keeping adequate airflow. Creating a simple straight through air flow with replaceable filters on the outside would be perfect. Also, try to use shielded cabling for high current, maybe with some ferrites for clamping, to reduce the interference to the PC and control signals, the interference can and most likely will be significant.
    cheers,
    Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Feb 2006
    7063
    Quote Originally Posted by gopher View Post
    Putting all the electronics into a single enclosure is no problem at all, IF good wiring practices are followed (shielding, grounding, etc.). My knee mill has ALL the electronics (dual power supplies, dual BOBs, ModIO, VFD, relay board, PC, SmoothStepper, etc) in a single enclosure, and it works flawlessly. But hanging it all off the X2? Not a great deal, given how flexy the X2 is already.
    Oct 2005
    2392
    I would also advise against it, due to vibration.
  1. Electronics Enclosure + VFD
    By rwskinner in forum Automation Technology Products
    Last Post: 01-15-2010, 03:49 AM
  2. Electronics Enclosure Build
    By BobWarfield in forum Charter Oak Automation Support Forum
    Last Post: 04-08-2009, 03:37 PM
  3. Electrical/Electronics Enclosure
    By audioandy1762 in forum DIY CNC Router Table Machines
    Last Post: 02-27-2007, 01:32 PM
  4. Not sure what to do about electronics enclosure
    By phantomcow2 in forum Benchtop Machines
    Last Post: 02-08-2007, 05:29 PM
  5. Electronics Enclosure Box
    By JavaDog in forum CNC Machine Related Electronics
    Last Post: 04-22-2005, 02:00 AM
