586,089 active members*
3,897 visitors online*
Results 1 to 7 of 7
    Apr 2010
    Error Codes on Servopack.
    Hello. I am using Yaskawa Servopack SGDH 04AE ver. 3AA44 and a Yaskawa AC servo motor SGMAH - 04AAF41. I keep getting error code on my servopack. One being A.71 and the other being 66. It is causing my cnc plasma table to stop in mid cuts or not even start up. The gantry will move all the way down the table but most of the times when the touch goes to move along the Y-axis it will hard stop, making a sound like something locked up, and give me one of those errors on the my servopacks. Any help would be awesome.
    Feb 2009
    6028
    Don't see a 66, but a 71 is a overload
    The motor was running for several
    seconds to several tens of
    seconds under a torque largely
    exceeding ratings.
    Sounds like you have a mechanical problem to me.
    Feb 2009
    6028
    BTW, you can get free manuals and software on Yaskawas web site. Sigma Win is free software for your laptop to troubleshoot these drives.
    Aug 2015
    Re: Error Codes on Servopack.
    Hello, Am using Yaskawa servo pack 200V, SGDV-7R6A01A. I keep getting error code F10 and the other is Pot /not causing all on my CNC router to stop. Any help?
    15362
    kjferg
    The 66 is the no power to the servo motor, you will always see this on startup, you get 66 then it will change to Run,if everything checks out ok, when you see the Run you have power to the motor, the 66 you are seeing may be from the A71 Motor overload alarm, it is trying to protect the servo drive
    Mactec54
    15362
    Quote Originally Posted by Mawuli View Post
    A.F10 is main input supply voltage was low on ( 1 ) of your input phases to the servo drive
    Mactec54
    Jan 2017
    44
    in fact ''66'' is ''bb'' base bloc
  1. Yaskawa Servopack error: A.D1. Motor Load Position Excess Error
    By Syphonics in forum Servo Motors / Drives
    Last Post: 04-26-2012, 07:53 AM
  2. Rover 322 Servopack Error Message
    By verdan in forum CNC Machining Centers
    Last Post: 03-11-2011, 09:59 AM
  3. Error Codes
    By MegaMoog in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-25-2007, 03:08 AM
  4. Error codes
    By Jenks in forum Commercial CNC Wood Routers
    Last Post: 03-14-2006, 01:39 AM
  5. Fadal error codes
    By HareBall in forum Fadal
    Last Post: 01-22-2005, 02:52 PM
