586,069 active members*
3,271 visitors online*
Page 14 of 16 41213141516
Results 261 to 280 of 305
  1. #261
    May 2009
    40
    I recommend the sizes (approximately, very difficult and not linear dependence)
    For small furnaces height of liquid metal / diameter of liquid metal = 0,5
    For the big furnaces from 0,5 to 1
    The coil
    Internal diameter / height = 1 - 1,2 (approximately, depends on thermal losses)
    Coil height / height of liquid metal 0,9-1.3 (depends on thermal losses)
    In small furnaces - small EFFICIENCY, the basic problem thermal losses.
    I have specified factor of transformation 1/10 - 1/20 for connected one after another (not parallel) the coil and the condenser, a resonance on a secondary coil (low voltage)
    For an input in the inverter of 220 volt of 50 Hz
    The thermal protection for your furnace the coil/ crucible, is enough 2-2.5 sm
    Thickness of a crucible not less than 5 mm (I am not assured, there is no operational experience with stainless steel
    For an ordinary steel of 10 mm 17 000 Hz), desirable frequency of 66 000 Hz. It will allow to apply and a crucible from graphite
    If you do not have electric leaks, it is possible to manage and without coil isolation.
    I do isolation by special fiber glass fabric by the impregnated pitch
    Two layers a thickness of a layer of 0,2 mm. I wind a copper tube on all length, a photo I will show after. Water in the coil cools isolation.
    For industrial big coils, isolation multilayered, difficult
    "Should I protect the inner wall of the crucible with some "stuff"?"
    It is desirable, aluminium reacts with iron, but it is very difficult. I the reference to manufacturers of crucibles.
    For a house, fusion admit also a steel crucible, OK
    Photo of furnaces for jewellers
    http://www.mexel.narod.ru/Foto.html
    The sizes of graphite crucibles for fusion of gold, silver, copper, FOR independent manufacturing
    http://www.mexel.narod.ru/Tigel.html
    Designs of furnaces
    http://www.mexel.narod.ru/Draiv2.html
    Thermal protection of crucibles, the sizes
    http://www.mexel.narod.ru/Draiv1.html
    http://www.mexel.ru/
    Site in Russian
  2. #262
    T3sl4 Guest
    The choice of coil size also depends on required coupling. A resonant coupled system (series or LLC network) will deliver maximum power output at only one load level. If loaded lightly, current limiting restricts power output. If loaded heavily, Q drops and "Q multiplication" no longer provides enough voltage or current gain; the limiting case is a short circuit, where the system is no longer resonant at all. (On the plus side, this type of system is short-proof.) If current is not limited (by reducing voltage or changing frequency), then maximum power is delivered when unloaded (dissipated as resistive loss in the work coil and dielectric loss in the tank capacitor).
    A constant voltage tank will deliver more current into a heavier load, acting much like an ordinary transformer. One example is a self-excited class C oscillator, like this,
    from which I got about 100W when scaled up:
    Downsides include low efficiency, the danger of quenching oscillation (resulting in sudden large power dissipation) and an inconvienient 'feedback' winding around the work coil. Generally, operation is with the transistor as a saturated switch, so the peak amplitude will always be slightly less than the supply voltage. If saturation slips, then amplitude drops, resulting in less feedback, and pretty soon oscillation stops and the transistor is dissipating full bias current.
    Variations on this, with a traditional switching approach (e.g., full bridge output stage), can be imagined. (Yes, driving a parallel resonant tank with a full bridge, no series inductor. A constant current supply is required, however.) Stability then becomes a matter of control circuitry.
    The nice thing about driving the tank parallel is you can drive as hard as you want. This is very important when, for instance, heating cold steel with a tight-fitting coil, which might have a Q of 2 or less in resonant terms. It stops looking like a resonant tank and more like a transformer with power factor correction!
    As for microcontrollers (mentioned earlier), if you have lots of experience, go right ahead and do it. If you don't, you'll probably end up writing a buggy program and neglect possible startup and shutdown conditions. The microcontroller doesn't give a damn if its outputs end up high at the same time... an SG3524 does!
    FYI, I may write a program to replace the moderately sized control board in my kit, with the added bonus of LCD display, menu driven control and timer functions. When used properly, microcontrollers can deliver the required signals safely, greatly simplifying the circuit, while adding complex and precise features. I'm worried that interfacing the signals will take as much analog circuitry as building it all in analog in the first place
    Tim
  3. #263
    Oct 2009
    5
    help needed for induction furnace
    Quote Originally Posted by chistyakov1971 View Post
    CD4046 -Smooth adjustment for frequency,good PLL
    The microcontroller provides the big step of step-type behaviour of frequency and cannot be good PLL, Small speed PLL
    Dear chistyakov1971,
    Hi, I am siamon99 and member of cnc zone not long enough, I had seen your posts on melting and casting forum, Iam a mechenicat engineer and involve in techenical jobs regarding melting and casting of copper and copper alloys. I think that melting coppor in an induction melting furnace is benifical due to short melting time required in induction melting furnace. What is your observation. Seacondly i am intrusted in building induction melting furnace 25 KW running on 440v 3phase 60Hz if you have any circut diagram of it electrical power supply unit i am willing to pay its price. Kindly let me know if you are intrusted in this deal, and the price the out put frequency should be 30KHz with power out put of 25 KW.
    Kind Regards
    Siamon99
  4. #264
    Oct 2009
    5
    My power module for the inverter of 30-40 kw
    Control system, the driver - are already made and adjusted.
    There was an assemblage in the case.
    I will be engaged in assemblage after start of the module for fusion of a steel of 1.5 kg.
    Is your power module based on IGBT or you have any designe for a 25 KW induction furnace i am intrusted in it.
    siammon 99
  5. #265
    May 2009
    40
    siamon99
    Look mail
    I have this scheme for industrial use, serial release of inverters, for induction heating and an induction melting furnace
    I have possibility to develop the scheme for your conditions, at professional level
    Has 10 channels of protection
    Drives on the ACPL-333
    look post 234
  6. #266
    Jan 2010
    Open Source Induction Furnace Project
    Have you guys seen this project from Open Source Ecology?
    They're offering from US$ 1k to 3k to the best induction furnace project submitted.
    The project should include:
    1. Design of an induction furnace circuit scalable up to 50 kW in units of 1 or 5 kW
    2. Design allows for power and frequency selection
    3. Power source may be either 1 or 3 phase electrical power.
    4. Specifications of a cooling or heat dissipation system
    5. Adaptable design specifications for primary coil windings
    6. Geometrical design of melt chamber and basic power transfer calculations
    7. Melt chamber includes provisions for loading and pouring.
    8. Complete bill of materials
    9. Fabrication files for circuit and other components
    10. Sourcing information for components
    11. System design and process flow drawings
    You can learn more at their page.
  7. #267
    May 2009
    40
    Thanks for the reference.
    I have all.
    Only there is no desire to participate. My opinion: competitions it is swindle on gathering of schemes
    Induction heating is very old theme for inventions.
    To think up something new it is very difficult and it is unreal
  8. #268
    T3sl4 Guest
    That furnace looks good. The next step is lining with refractory?
    What is the board material on top?
    Do you have a problem with the steel parts heating up from the magnetic field? I would use heavy aluminum near the coil.
    Tim
  9. #269
    May 2009
    40
    The following step crucible creation, material Finmix 0.5
    The technology is debugged and applied in industrial induction furnaces.
    Furnace top: assemblage of the asbesto-cement plates, special, heat-resistant.
    I envy you, you can apply plates for example: Fiberfrax
    Problems with a steel skeleton are not present. A steel: corrosion-proof, not the magnetic.
    Approximate your analogue 18/10.
    The furnace design corresponds to norms for industrial furnaces.
    Aluminium can apply, look sites on manufacture of induction furnaces in China. There it is a lot of photos
    Attention! The no closed horizontal contours
  10. #270
    Apr 2009
    7
    great work chistyakov1971! I want to build one
    I want to see the first steel casting .
  11. #271
    May 2009
    40
    The induction furnace is constructed and handed over the customer.
    Works in laboratory.
    Unfortunately I have no access to laboratories, a private property and other organisation
    Now I work over installation of induction heating for volume hot punching
  12. #272
    Oct 2009
    5
    siamon99
    Look mail
    look post 234
    Dear chistyokov1977
    Iwant to use induction furnace for melting coppor
    Cruicable material graphite
    In put supply 3 phase 440 volts 50 HZ
    Out put 20 KW 500 volts 30 KHZ
    Material melted in one charge 15 KG
    IGBT based circut.
    Charges will be paid by me to be agreed in advance
    siamon99
  13. #273
    May 2009
    40
    Look the mail
  14. #274
    Jul 2004
    242
    If anyone is interested I have a copy of the schematics that were originally posted on the hvguy aka Aron Koscho & Justin Hays website (the current website is infected with a virus). They were for a 2.5kW unit. If someone has a way to host them, shoot me an email and I'll email you the whole nine yards, I saved the web page a long time ago for off line viewing. If someone takes the initiative to produce boards for the design, let me know as I'd like to build the unit for heat treating use.
  15. #275
    May 2009
    40
    New works :
    2 KW, 66 kHz, for melting Cu, Ag, Au
    and 30KW
    without the commentaries
    Old photo, adjustment
  16. #276
    Jan 2008
    Cool Induction heater page
    I have been interested in induction heating for the better part of a decade, and have given in and bought several commercial units. The gist of it is, if it's good, it's expensive (like the Magneforce 1500R I bought), and if they are cheap they usually don't work well or don't last long.
    I don;t know what the linking rules are here, but if you do a search for Neon John Induction Heater you'll find a very cool page. Unlike all the other blog pages, here you can actually find plans, pcb layouts and ExpressPCB files, and loads of USEFUL information.
    If you are on a budget, this is a great place to get some traction on your project....
    FYI
    G
  17. #277
    May 2009
    40
    Old photos,
    The sample for debugging, 66 кГц, 2 kw
    The first melting, 13 minutes (cold start)
    The subsequent meltings approximately 4 minutes
    Defect of casting from for the cold molds
    The experiment purpose not copper fusion.
    The experiment purpose: research of characteristics of the furnace
  18. #278
    T3sl4 Guest
    I've got my improved version cooking:
    [nomedia="http://www.youtube.com/watch?v=fE8_-i931zw"]YouTube- Big Induction Heater[/nomedia]
  19. #279
    Sep 2005
    1195
    chistyakov1971,
    Is it possible to make 5" long tubing/pipe 3-1/2" OD with .25" thichness to become red hot with 2000 w induction furnace. I plan to expand end of tubing about 4"-5" long. Thanks.
  20. #280
    May 2009
    40
    Now I work over the similar furnace.
    I can not give consultation
  1. 12.5 kW Induction Furnace
    By meanu in forum Casting Metals
    Last Post: 04-24-2013, 07:19 AM
  2. My Furnace
    By vertek in forum Casting Metals
    Last Post: 02-28-2008, 07:15 AM
  3. induction furnace
    By vallabesan in forum CNC Machine Related Electronics
    Last Post: 12-13-2007, 04:19 AM
  4. Arc Furnace
    By aggie_67 in forum Casting Metals
    Last Post: 08-28-2007, 06:27 AM
  5. DIY Oil Furnace
    Last Post: 09-24-2006, 02:35 PM
