Originally Posted by
Shawn D
This sounds like an Emergency situation. In this situation, I would shutdown all power in the induction system AND close a solenoid on the supply and return side. I would still allow water to circulate in the induction power supply, just not the coil.
But, I thought that the previous comments were talking about shutting the water off to the coil in a non-emergency shutdown.
So, how do you monitor for a leak near the hot zone?
Electrical leakage to earth. My coolant is at something like 40 psi so a small leak goes a long way !
I keep my coolant circulating for quite a long time after shutting down the driver electronics as if I stopped the pump too soon the now static water in the coils would be in grave danger of boiling
Andrew Mawson
East Sussex, UK
