Is there anything special I need to do when installing Bobcad 23? I installed it, but an error was listed, and I don't remember what it was.
Thanks.
Thanks.
You have to set run as administrator.
How is that done?
Thanks.
Right clcik on the icon you use to launch BobCad and choose properties. Then on the compatability tab, look for "run as Administrator". This keeps UAC from interfering with normal operation.
Here is the error, Feature transfer error, component: Support Application File,
File: D:\data2.cab, Error: Data error
Thanks.
It could be a bad download??? Re-download it. If it's a cd, try copy the contents of the CD to a folder on the desktop and run it from there... Also, try right clciking the installer/setup program and run it as admin too...
Got it, I had to download the newest version. I had 1518(?) on a CD, must been a problem with the earlier versions with windows 7.
Thanks.
I haven't used Bobcad, since this past January, when I lost my job. Now I'm looking into Solidworks, for more Cad exp.
Thanks.
