I need to make about 100 pcs of this part (attached), and need it ASAP, so want to do this myself. The part is made of 0.5" wide strips of 0.090" 5052 aluminum (which I already have). It's about 2" across with ~1" arms and 2 holes.
I have a drill, drill press, jig saw, good chop saw with carbide blade for aluminum, and a CNC mill. But I don't have a bending brake. I do have (if I can dig it up) a vise-brake like this, but in the past I've found that it breaks 0.125"-thick aluminum because the bend radius is *very* sharp. Haven't tried it with 0.090" yet, because I have to find it.
Either way, I'm looking for a way to make some type of jig that I can use to make these repeatably (ie: so it's a task rather than an art). I don't mind buying a tool (say $100?) but so far all the Harbor Freight & Northern tool offerings don't state they'll bend 0.090" aluminum. But this thing is easy to bend by hand or with a pair of pliers.
Perhaps I can just make a block that would be the same width as the inside width of this part, then just clamp the metal onto that, and using a glove just bend the metal around both sides the block. Should I drill the parts first? Then I'd also need to make a jig onto which I can clamp the part so it can be chop-sawed.
Any better (simpler) recommendations? Thanks.
