ah ok will try it.
Maybe you can help with another restart-related issue
Check the same program I posted before.
On restarting from the transfer (N110) the sub spindle goes into overtravel. It moves back about 2". Its not random, it does it every time when restarted from N110. When the program is run from start to finish it works fine. If I restart from any other place it works fine. I suspect it has something to do with the G00 Z50 lines from previous tools. Normally it would just go to maximum Z (which is the intention of that line) but on the transfer restart it seems to be trying to physically go to Z50 (max Z travel is about 20"-25"). Thus going into Z-overtravel :/
If this were a Fanuc I would use G28 etc but this doesn't seem to have a 'go home' command?
