586,089 active members*
3,876 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Profiles/Pocketing
Results 1 to 6 of 6
    Mar 2010
    Profiles/Pocketing
    I am doing a profile, which is basically a pocket and using a larger EM (.25 IN) to clear out the pocket. Then I need to drop down to a smaller EM (.125 IN) and clean up the corners with a finishing pass.
    How do you setup the file so secondary profiles for finish passes do not retrace over the entire inside of my pocket. I only need to make a finish pass and then let it radius the corners as it does that?
    Mar 2010
    Which I should add without using the Re-machining feature of the PRO version.
    Aug 2008
    386
    Create a cross-shaped avoid region to block off most of the pocket (assuming it's square).
    Joe
    Mar 2010
    Actually I figured out a way but have not machined it yet. I created a pocket MOP then followup with a profile. I would think given the same dimensions it should work.
    Quote Originally Posted by Magnum164 View Post
    I create three MOPs. The first for the pocket, leaving a few thou for cleanup. The second for profiling just the corners so that little EM isn't trying to take it all at once. And the third to profile and clean up the entire perimeter.
    Jan 2004
    3154
    Yep
    I usually use profile for both cutters but pocket and then profile is more politically correct.
    www.integratedmechanical.ca
  1. Mach3 Profiles
    By Drools in forum Mach Software (ArtSoft software)
    Last Post: 09-11-2009, 02:00 AM
  2. stock profiles
    By kendo in forum EdgeCam
    Last Post: 02-10-2009, 03:59 AM
  3. Z-Profiles
    By mrcodewiz in forum Dolphin CAD/CAM
    Last Post: 05-17-2008, 01:22 AM
  4. Rail profiles?
    By sp1nm0nkey in forum Linear and Rotary Motion
    Last Post: 02-04-2008, 07:11 PM
  5. Profiles for CNC lathe
    By Don C in forum Mini Lathe
    Last Post: 04-25-2005, 01:17 AM
