Hello.
What PDxxx do i need to change on, and how is it work?
I have read in the manual, but i don`t understand it correct..
Thanks.
Robert.
Hello.
Thanks.
Robert.
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
Do you have a PDF Manual of the VFD in question?
Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
Yes
Ok, that's a very bad manual, missing a lot of descriptions...
There is not mention (that I could find) that says what is the difference btw accel1 - accel4 ..
So, just try which one works, start from 1.
Set these:
PD014 Accel. Time 1 0.1~6500.0S *
PD015 Decel. Time 1 0.1~6500.0S *
PD016 Accel. Time 2 0.1~6500.0S *
PD017 Decel. Time 2 0.1~6500.0S *
PD018 Accel. Time 3 0.1~6500.0S *
PD019 Decel. Time 3 0.1~6500.0S *
PD020 Accel. Time 4 0.1~6500.0S *
PD021 Decel. Time 4 0.1~6500.0S *
Hub
And if you use S-Curve:
PD043 S-Curve Time
Maby you can take a look at this one too!?
http://www.cnczone.com/forums/machin...ge_before.html
Greetings from Robert.
Sure, I did. But Gerry already answered it correctly I think.
There is a buffer memory that contains lines of G-code.
They are already sent to the "controller" with the selected speed.
It has to process them first I think. Not sure since I don't know the exact way of how it's programmed.
Also, the step-pulsing is most likely a very high priority processing thread, and the speed change is likely a low one.
Just guessing here, but that's the most likely reason in my opinion.
