586,112 active members*
2,999 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > hardinge cobra 42 fanuc 21i control
Results 1 to 6 of 6
    Sep 2011
    Unhappy hardinge cobra 42 fanuc 21i control
    Machine is new has 2 hours runtime on it. I can't get programs in or out using the card / adapter or computer. I have looked the parameters over and all seem good. it acts like nothing is there computer or card. I have the cable wire 9 pin to a 25 pin 2 to 2 3 to 3 5 to 7 jumper on 25 pin end 6,8,20 cable works on all my other machines. Anyone out there with any clues on this one? What could it be? :tired:
    2932
    Have you changed the I/O device on the settings page to 4 for the card or 0 (or 1) for the RS232 port?
    Sep 2011
    hardinge cobra 42
    yes, I changed it when using the card and computer. The book says for the card use 4 in some places and 3 in others. Neither works. When using the computer use 0 no luck with it either. It has to be something easy and stupid I'm doing..
    KW
    2932
    Quote Originally Posted by waybriks View Post
    Are all your other machines Fanucs?
    Does OUTPUT blink in the lower right of the CRT when you PUNCH from the machine?
    You should have pins 4 and 5 jumped together on the CNC end also.
    If all else fails, go to Radio Shack or Fry's and get a ~$14 RS232 tester to check for activity on pins 2 and 3.
    Sep 2011
    othgers are fanucs cable works on all of them. I do have 4 & 5 jumped on the cnc end. output light blinks. I'm going for the tester. I will let you know the next developement
    thanks
    KW
    Sep 2011
    got it running, problem was in the parameters that are common to all output / input devices.
  1. hardinge conquest 42 VS cobra 42
    By mls in forum Hardinge Lathes
    Last Post: 09-07-2010, 10:42 PM
  2. Hardinge Cobra 51 & Fanuc 21i-T Question
    By CNCBahamas in forum Community Club House
    Last Post: 07-04-2010, 10:37 PM
  3. Hardinge cobra 65 collet closer
    By vsmvj in forum Uncategorised MetalWorking Machines
    Last Post: 07-30-2009, 03:13 PM
  4. Replies: 5
    Last Post: 09-02-2008, 02:36 PM
  5. Parameters on Cobra 42 Hardinge
    By Niall in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2004, 10:38 AM
