586,096 active members*
3,364 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam Lathe X4
    Jun 2009
    99
    Mastercam Lathe X4
    In MCAM X4 how do i get it to post an R value for the Radius instead of an I,J,K format?This is for any turning toolpath.I cant seem to find where to do this at, Is it in the post or is it a configuration setting?Where do i make this change?Thanks for any and all help.
    Sep 2011
    Try this..
    Go to machine type and use
    C:/USER/PUBLIC/DOCUME/LATHE C-AXISSLANTBEDMM.LMD-5
    That machine will post your radius' with the "R' value you need.
    Dec 2008
    3109
    In the Control Definitions file
    go -->
    - "Settings" pulldown
    - Edit Machine def
    - THEN, open the control def file
    - go to the "Arcs" tab (alter as your machine requires)
    Jun 2009
    99
    Superman thanks for your help ill give it a try in the morning.
  1. Mastercam lathe
    By Rafael18 in forum Mastercam
    Last Post: 02-16-2011, 02:49 AM
  2. mastercam lathe
    By Stran in forum Mastercam
    Last Post: 12-07-2009, 01:07 AM
  3. Mastercam Lathe?
    By MDISolutions in forum Mastercam
    Last Post: 01-03-2009, 04:51 AM
  4. Need help on Mastercam lathe V9
    By Bob Z in forum Mastercam
    Last Post: 11-06-2007, 02:23 AM
  5. Mastercam V9 Lathe
    By LIVVY111 in forum Uncategorised CAM Discussion
    Last Post: 09-27-2007, 02:06 PM
