586,269 active members*
3,260 visitors online*
    Aug 2011
    2517
    Tool Life Management on MSG-500
    Here's some pics of the Tool Life Management screens on my MSG-500 control.
    I can add a tool (or any number of tools) and set the time or usage to a number and set the remaining time/usage to another number. Here I've set the minutes to 10 and used is 9. So there's 1 minute to go for this tool.
    The problem is the time/usage does not count up at all. It appears to not be enabled? The SET and D and H columns are blank and there is no way to enter info there. Maybe they are supposed to be blank I don't know.
    Using G10L3 (etc) to fill the tool management data via a program does not work.
    If I put a G10 in the program it says ILLEGAL G CODE
    Anyone have access to a MSG-500/MSG-501/MSG-803 and used Tool Life Management and/or anyone know how the Tool Life Management works on this series of control?
    Attached Thumbnails Attached Thumbnails DSC00097.jpg   DSC00098.jpg   DSC00099.jpg   DSC00100.jpg
    Aug 2011
    2517
    I found out to enable the Tool Life Management requires a Mori-specific G-code
    The current Mori's like NT on MAPPS III etc use it like this....
    G336 T1.
    The 1 tells it which tool group to use.
    However it seems between MSG-500 (my MAPPS I control circa 2000) and MSC-504 (a manual I have circa 2007) they changed the way G336 works.
    On my machine it turns on the function but the machine just sits there waiting with the cycle light on :/
    If I press reset the tool life counter increments by 1!
  1. management of tool life
    By hongjianming in forum CNC Swiss Screw Machines
    Last Post: 07-28-2010, 05:41 PM
  2. Tool life management
    By Robman01 in forum Okuma
    Last Post: 05-18-2010, 02:23 AM
  3. Tool Life Management
    By marko440 in forum Fanuc
    Last Post: 04-07-2010, 09:47 PM
  4. Renishaw tool offset / break probe and tool life management
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-21-2010, 04:14 AM
  5. Tool Life Management
    By Jake E. in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-05-2009, 08:13 PM
