What are the standard file extensions accepted by the DX-32 Controllers? I know .txt, but are there anymore? My EZTrak uses .pgm for its standard file extension but accepts .txt as well.
Since NC files are ascii text it really doesn't matter what the file extension is.
If your control doesn't like a particular file extension, rename it. Won't affect the NC code.
Joe
In LOAD it will only look for TXT extensions. You also have to follow DOS rules in naming the file.
George
I was just curious on the matter. I just bought a Torq-Cut 22 and was unsure as to what file extensions it typically used. Thanks for your input.
