586,082 active members*
3,541 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Adding a mass/weight value to a model
    Jun 2010
    60
    Question Adding a mass/weight value to a model
    Is it possibly to add a mass/weight value to a model?
    We use a lot of 3rd party products, that I download from company sites(where available), in assemblies.
    Sometime I even just build a block to represent an item. The looks and materials are not important but the weight is as most times I have to keep the whole assembly within a specified weight. On 2 occasions I also needed the centre of gravity to show a client his ideas were not ideal.
    Any ideas?
    C
    I'm not exactly sure what you are asking to do when you say "Add weight/mass information to the model"
    If you mean that you want to "pull" the information, you can go to Tools > Mass Properties. Be sure to set the density to the density of the material that the part is made out of.
    If you want to add it in as a property, you go to File > Properties and navigate to the "Custom" tab where you can add any number of properties.
    If you want to have a "sensor" that alerts you when your model is out of your tolerance values for either Mass or Center of Mass, you set up a "sensor" by right clicking on the "sensor" folder in your feature tree. If you don't see that folder, you right click in your feature tree and navigate to Hidden Tree Items > Hide/Show Tree Items and "Show" the sensor item.
    You can make a macro that gather's the Center of Mass info and adds a point to the model in the location of the Center of Mass every time the model Rebuilds (or every time it is initiated). You can also make the same macro display a dialog of the mass info.
    mechengineer
    http://EdenCAD.com
    Jun 2010
    60
    Thanks Mecheng.
    I did find what i want
    Mass properties- Check box "Assigned Mass Properties"
    Stick the motor on a scale and type in the value!
    Too easy
    And yes adding the sensor would make life much easier. Never done it, so I will have to play.
    And to be honest, until now I have never needed to use a macro. So I know not how! Some more playing needed
    Thanks for the help
    C
  1. adding clearance to existing model
    By Gncc50 in forum Mastercam
    Last Post: 01-08-2009, 05:48 AM
  2. Mass-cnc Job Opportunity
    By mkmk123 in forum Employment Opportunity
    Last Post: 09-18-2007, 11:58 PM
  3. Mass software?
    By bdrmachine in forum Mechanical Calculations/Engineering Design
    Last Post: 01-19-2007, 08:33 PM
  4. Need CNC Machinists in MASS
    By StarCatcher in forum Employment Opportunity
    Last Post: 10-27-2006, 07:14 AM
  5. mass produced
    By skeetboy25 in forum I.C. Engines
    Last Post: 08-12-2003, 01:47 AM
