586,096 active members*
3,762 visitors online*
Results 1 to 8 of 8
    Jun 2011
    13
    Question Galil DMC-2143 - Red LED
    Hi everyone!
    I mistakenly applied 10.7V to the pin 63 (Reset) instead of sinking it to 0 (zero) volt, for a split second. Now the red LED is ON all the time and I can no longer communicate with the board. However it still has the same voltage reading that it used to have on all the 96 pins, except the X, Y, Z & W Amp Enable. Which makes sense: If there is a fault, all the axes should be disabled...
    The reset pin goes straight to the IC U35 (see attached picture). Could anybody help me find this IC? It is smaller than a grain of rice and appears to be made by Texas Instruments. Since I overpower it, I will replace it first and go from there!
    Any help will be greatly appreciated!
    Luiz
    24221
    Check out MAX708 micro version.
    http://datasheets.maxim-ic.com/en/ds/MAX705-MAX813L.pdf
    I have Galil boards that use the same IC and the schematic show the external reset going to this IC.
    Al.
    Albert E.
    Jun 2011
    13
    DMC-2143 U35
    Al.
    I downloaded their PDF! Is it a direct replacement for the ...C7LF...? How did you figured that?! The card works without it! If it has no other function, I will just leave it like it is!
    Could you please sent me a copy of the schematics (Preferable DMC-2143), or let me know how I can get one?
    Thanks a lot!!!
    Luiz
    24221
    The schematic is for an older ISA card so it won't relate to the 2143, the card had the identical IC and the print was marked MAX708.
    It only shows two connections to the chip, I can copy the page if you want.
    Al.
    Albert E.
    Jun 2011
    13
    Al.
    Sure! Please send me a copy!
    By what I've seen on the board, one track goes to the pin 63 and another one goes to the GL-1800. I couldn't tell if there are any other connections...
    Thank you!
    24221
    PDF of MAX708 U2
    Al.
    Attached Files Attached Files
    Albert E.
    24221
    I reposted the PDF after I realized I had cut some of the copy off.
    Al.
    Albert E.
    Jun 2011
    13
    Re: Galil DMC-2143 - Red LED
    Al_The_Man, I haven't posted in years, and I just came across this thread, and I am sorry that it took so long for me to thank you! I did replace that IC long time ago and it worked! Thank you so much!
    https://www.youtube.com/watch?v=EeMsZmbrl98
  1. Galil Servo Design Kit / Galil Suite
    By Neo20X in forum Controller Cards
    Last Post: 03-12-2013, 11:31 PM
  2. Who PM'd for Galil VBX
    By Al_The_Man in forum Controller Cards
    Last Post: 05-01-2010, 04:58 PM
  3. other than Galil
    By bobk in forum CamSoft Products
    Last Post: 12-30-2009, 11:39 PM
  4. Galil Anyone
    By Al_The_Man in forum Servo Motors / Drives
    Last Post: 10-29-2006, 08:52 PM
  5. Sure Servo to Galil
    By Mountain in forum CamSoft Products
    Last Post: 07-05-2006, 06:40 PM
