586,114 active members*
3,345 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Heatsinking G250x, Part 2
Results 1 to 7 of 7
    May 2005
    925
    After giving it a tought I came up with this idea, it will allow to use G250x pulled out of G540's (we only use 2 for the lathes) like a regular drive, the PCB is single sided so it can be machined or etched easily, the heatsink doubles as a support for the green terminal block, once I gather enough G250x out of g540s I will make a small batch of these and post photos
    Pablo
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Dec 2007
    362
    Hi Pablo,
    Did you ever end up designing/making any of these interface cards?
    I've got some cheap Chinese drivers to replace and I have a stack of G250s just ready for such a use.
    Regards
    Geoff
    May 2005
    925
    Last week I purchased the terminals at digikey because I cannot find them here with 3.5mm pitch, I guess 10 more days to arrive here and then its build time
    Pablo
    Dec 2007
    362
    Gecko to the rescue
    After communications with Gecko, I've been able to buy some G540 mother boards to mount the G250s on. As my G250s have a female socket as does the G540 board, I'll need to use some header pins to connect them.
    Thanks Gecko!
    Regards
    Geoff
    Have you considered porting the G250 outputs to Tyco MTA-156 or MTA-100 style connectors? They are IDC (insulation displacement connectors) that are incredibly cheap (<$0.20) and very reliable up to 7A and 5A respectively. They are what you see in your washing machine or other major appliance if you tear it up just to see what's inside.
    Mariss
    May 2005
    925
    Quote Originally Posted by port_huon View Post
    Thanks Gecko!
    Purchased all the parts but never build the boards, I just read your post and decided to send an email to Gecko, if the price is right I might go your way too.
    Pablo
    May 2005
    925
    Sent the email but I got a fast reply (Thanks!!) telling me that Rev.2 g250x boards are not compatible with Rev.8 motherboards, so I guess I will have to do the first post design...
    Pablo
  1. Heatsinking G250x, kapton tape+bare aluminium?
    By PEU in forum Gecko Drives
    Last Post: 09-14-2011, 08:33 PM
  2. Geckos and heatsinking
    By Zeljkoc in forum Gecko Drives
    Last Post: 11-10-2010, 10:47 PM
  3. Newb ? - CAD Part interference & mating part dims
    By pabmartin in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2009, 07:18 AM
  4. Heatsinking the HP-UHU
    By H.O in forum UHU Servo Controllers
    Last Post: 11-02-2009, 11:45 PM
  5. Heatsinking Your G540
    By CoAMarcus in forum Gecko Drives
    Last Post: 02-24-2009, 08:33 PM
