Mach 3 default setup (as supplied for Taig) senses eStop on parallel port Pin 10.
I'd like to install an external eStop push button but don't really want to break out Pin 10 from the controller box. I can easily connect a switch to a pin on a second parallel port and re define it in Mach3.
Does anyone know if the Taig controller ever uses the eStop wired to Pin 10? If it does I will have to wire into the controller box. Thanks.
