586,106 active members*
3,160 visitors online*
Results 1 to 8 of 8
    Sep 2005
    10
    Holding down material
    Can someone tell me how this chunk of Al is being held down?
    http://www.cncmotion.com/aluminum.mpg
    There are no clamps, and the table does not seem designed for vac?
    Cheers
    Stephen.
    Apr 2003
    1873
    I think they use aluminum magnents
    It almost has to be vac, that seem to make the only sense of all the grid work sections.
    What ever it is, it's doing a great job.
    Mar 2005
    1136
    http://www.cncmotion.com/standard.htm
    well my money's on a Rietschle® 10 HP Vacuum Pump
    there's some cool videos on that site - I think i want a cnc wood lathe after seeing that clip
    Apr 2003
    1873
    Yeah, they are pretty cool, I am watching the lathe right now.
    Aug 2005
    34
    My father use to use a double back tape made by 3M for Fly cutting aluminum. No clamps! He said it was precision tape. If memory surves me right he bought it at Reid Tool and supply. He would wipe the mill table and work piece with acetone and apply the tape. He would lay the work piece on the mill table and hit a few times with a rubber mallet. The work piece had to be flat. The first time I saw him do this, I stood on the other side of the shop. To remove the piece he would slide a screwdriver underneath the piece in the T slots and pry it up. We never removed to much material this way ~0.02” max. Although it would depend on the cutter and feed rate and a touch of common sense.
    Apr 2003
    1876
    Looks like a vacuum table. The slots/grooves you see are typically filled with gasket material to create the vacuum. It's a very generic fixture that can be used on many simple applications.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Sep 2005
    10
    Quote Originally Posted by Rekd
    Intreasting.
    Thanks.
    Stephen
    Feb 2005
    921
    Just watched the videos. The CNC wood lathes do look pretty cool.
    Quote Originally Posted by Mcgyver
