586,410 active members*
2,877 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > LazyCam not generating G-Code
    19
    I have gotten my Solsylva CNC machine up and running and have managed to create a good test piece in foam of Homer Simpson and the Indian motorcylce logo. So this I feel is a good start. I wanted to start cutting some parts out of wood but came across a problem trying to generate the G-code for the parts using LazyCam. The first part that I tried is simply a square with a round recessed pocket in the middle. The part is only 1/2 thick with a 1/4 pocket depth. I plugged in what information I needed in LazyCam but it will not generate the G-code for Mach3. The engravings worked beautifully. Does anyone know what is happening here? I could use the help. Thanks.
    I don't use or recommend LazyCAM, but there's a manual here that might help.
  1. Replies: 3
    Last Post: 04-29-2011, 07:12 AM
  2. LazyCam only generating 49 lines of Gcode
    By SigUser in forum Mach Software (ArtSoft software)
    Last Post: 05-07-2010, 12:12 AM
  3. LazyCam Code Posting
    By Telly in forum Machines running Mach Software
    Last Post: 12-22-2009, 02:22 PM
  4. Generating code with Camsoft AS3000
    By Bap in forum CamSoft Products
    Last Post: 09-21-2007, 07:26 PM
  5. Generating code from solid
    By adryan in forum BobCad-Cam
    Last Post: 03-06-2007, 11:10 PM
