It sounds like you might have gotten the incorrect switch. There are two different types, "normally open" and "normally closed", or N/C and N/O.
Depending on the configuration of the switch, it might be adjustable. If it has only two wires coming out then probably not. If it has three then you could. That is why most simple switches have three connections on them. One common and one for N/C and one for N/O.
Mike
Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
