586,106 active members*
3,105 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > new plasma&flame cutting machine offer
    Mar 2010
    141
    DesktopCUT
    DesktopCUT is a high speed precision plasma cutting machine; apply to thin metal sheet and panel beating
    Easy and fast installation, no need to build foundation and sheet support
    Compact modular construction, fume extraction table or underwater table is optional
    Dual-side drive, bilateral straight guide rail oriented make cutting accuracy more precise.
    Fume extraction structure and pure physical construction can reduce the stoppage made by electric component
    Adopt high precision arc height control system with up/down stroke of 150mm
    Specification
    model 1530
    effective range 1500x3050
    overall width 2600
    overall length 4300
    X axis high precise pinion and rack gear , effective length 1600mm / 2100mm
    Y axis high precise pinion and rack gear , effective length 3200mm / 6200mm
    Z axis ball screw and straight guide rail, up/down stroke 150mm
    Max. cutting thickness depend on the plasma power source, up to 50mm
    Drive system Mitsubishi or Panasonic AC servo motor
    operate system MicroHYD / HYDPRO / MicroEDGE / EDGEPRO
    resetting accuracy ±0.1mm
    rapid moving speed 12000mm/min
    fume extraction system simple fume extraction system or Donaldson dustcollector
    plasma power source according to the thickness of the metal sheet, match with plasma from 20A to 260A
    The machine can be made according to customer's request.
    Price depends on customer's machine specs.
    Fiber laser cutting machine
    http://qlaser.en.alibaba.com/
    Apr 2006
    3206
    Looks like a swell system!
    So good in fact, you ought to work out a deal with CNCZone as an advertiser, so every time someone clicks on your link here they get a small token.
    Not to suggest that you're getting/asking for free advertising or anything..
    Just think of it as a nice gesture.
    Mar 2010
    141
    Quote Originally Posted by fizzissist View Post
    Thanks.
    Actually it is not our product, but our customer's. we just design the CNC system and THC for this machine.
    They newly started to export their machine, so I posted it here as I thought it is a good place for promotion of machines. I just wish to help them.
    If the feedback is convinceable, they will be glad to buy ad here, as they are looking for such a place.
    larry
  1. CNC controller for flame&plasma cutting
    By larryy1022 in forum News Announcements
    Last Post: 04-19-2011, 05:08 AM
  2. ignitor for cnc flame cutting machine
    Last Post: 03-21-2011, 09:13 AM
  3. Replies: 0
    Last Post: 01-26-2010, 02:53 AM
  4. offer laser cutting machine
    By wktina in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-19-2009, 08:44 AM
  5. Laser cutting and engraving machine offer
    By beyondlaser in forum News Announcements
    Last Post: 03-27-2008, 08:23 AM
