586,103 active members*
3,342 visitors online*
Thread: EMC and Mesa
    Nov 2005
    111
    EMC and Mesa
    It's possible to use the Mesa 5i20 out of the Pc in a extra box ? With a converter Pci-e to Pci or is there a better way ? I think it's easier for wiring the 5i20 and daughter boards and the connectors for servodrive , encoder and i/o's .
    Many thanks for every answer
    Hans
    Feb 2008
    644
    Quote Originally Posted by Holzwurm56 View Post
    Hans
    Its possible but a little awkward mechanically with a PCI card. If you want all the I/O out of the box there are several options with different prices and capabilities. Here are a few options
    1. You can use a 3X20/7I68 externally and a 5I71 or 6I71 PCIE extender in the PC box. This is expensive (~$600) but has 144 I/O points and a large FPGA
    2 You can use a 4I73 with stacked 4I65/4I68/4I69 FPGA card and again a 5I71 or 6I71 cabled PCIE extender (this is a little less expensive ~$400)
    3. You could use a 5I25 plus 7I77 (This is the cheapest for a up to 6 channel servo interface ~$250 but the 7I77 is not quite available yet)
    4. Wait for the 7I80-CBB external PCIE FPGA card (also cheap and works with standard 50 pin daughtercards)
    Nov 2005
    111
    Hi PCW Mesa,
    many thanks for your answer . Works EMC with the Mesa 7i80 ?
    Hans
    Feb 2008
    644
    Hi PCW Mesa,
    Hans
    It should work with nothing more than a 1 line patch to change the subsystem ID, hardware wise (register level) its identical to all of our cards
    May 2005
    925
    do you have pdf info for the 7i80, 7i76 and 7i77? found no info on your site for these. Thanks!!
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
  1. Mesa punzonadora
    By ferlemega in forum Spanish
    Last Post: 08-31-2010, 11:08 PM
  2. Brand new to EMC,need some Mesa help
    By JR1050 in forum LinuxCNC (formerly EMC2)
    Last Post: 06-11-2010, 04:04 PM
  3. Mesa de agua
    By goyoasturias in forum Spanish
    Last Post: 01-09-2009, 08:06 PM
  4. Mesa, AZ
    By john matthews in forum Mentors & Apprentice Locator
    Last Post: 08-24-2008, 07:48 PM
  5. Mesa 5i20 and EMC
    By daedalus in forum LinuxCNC (formerly EMC2)
    Last Post: 06-27-2007, 08:19 PM
