586,993 active members*
2,907 visitors online*
Results 1 to 11 of 11
    Sep 2011
    Question Mastercam to Mach3 Turn Post Processor
    Hello All,
    I have a Wabeco lathe with a Mach3 Turn controller. I'm trying to generate the gcode in Mastercam X4, but the post processor file that I have in not generating the proper code for my machine. Does anyone have a post processor for Mastercam to Mach3 Turn, or would someone be able to write one for me? Please help!
    May 2004
    4519
    This one is for X5. If it does not work, you can probably use it as a template for making one for X4.
    http://www.mastercam.com/TeachersStu...LATHE%20X5.ZIP
    May 2004
    4519
    Sep 2011
    Thanks, that seems to work. Any idea how to get Mastercam to output a G32 instead of a G76? I've already tried changing the thread parameters to longhand. With it set to longhand it just produces this:
    N980 T0707
    N990 G97 S600 M3
    N1000 G0 X.2875 Z1.2091 M9
    N1010 M9
    N1020 T0700
    N1030 M30
    Any Ideas?
    May 2004
    4519
    What did you set in parameters for number of cuts, etc.? I just did a sample file and used the longhand option and got:
    G99 G32 Z-1. E.07692
    G0 X.7
    Z.2209
    X.4811
    G32 Z-1. E.07692
    G0 X.7
    Z.2183
    X.4717
    G32 Z-1. E.07692
    G0 X.7
    Z.2157
    If your parameters for cutting are correct, then there is something in the post-processor that will not allow the G32 longhand option to be output correctly.
    Sep 2011
    I looked at the post processor file but I'm not sure what I'm looking for. I did another test and I’m still getting the same results.
    N1180 T0707
    N1190 G97 S600 M3
    N1200 G0 X.2875 Z1.2211 M9
    N1210 M9
    N1220 T0700
    N1230 M30
    May 2004
    4519
    You did not say which of the posts you used. I have MasterCAM X3 and used the post for X5 and got the following G-code:
    N100 X.35 Z.0578
    N110 X.2454
    N120 G99 G32 Z-1. F.0769
    N130 G0 X.35
    N140 Z.0552
    N150 X.2408
    N160 G32 Z-1. F.07692
    N170 G0 X.35
    N180 Z.0527
    N190 X.2361
    N200 G32 Z-1. F.07692
    N210 G0 X.35
    N220 Z.0501
    No idea why you are having difficulties.
    Sep 2011
    I used the X5 post with version X4. I guess I'll just have to play with all the setting to see what works. Time for trial and error. Thanks for all the help Tx.
    May 2004
    4519
    I do not know what you were using for your base machine. I think I used the default lathe and control and added the Mach 3 post for MasterCAM X5 for the post processor.
    Sep 2011
    I changed the machine to default and problem solved.
    May 2004
    4519
    Good deal. Happy machining.
  1. UGS NX5 turn mill post processor wanted
    By CCLow in forum Uncategorised CAM Discussion
    Last Post: 08-05-2011, 02:43 AM
  2. FeatureCAM V.13 Mach3 Turn Post Proccesor !
    By AbuTarif in forum FeatureCAM CAD/CAM
    Last Post: 06-21-2011, 05:53 PM
  3. Which Post Processor for Mach3?
    By WarrenW in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-23-2009, 10:16 AM
  4. Editing Post Processor to Turn Spindle On and Off
    By DonFrambach in forum Vectric
    Last Post: 12-08-2008, 07:12 PM
  5. Post Processor For Mach3
    By southernexplore in forum BobCad-Cam
    Last Post: 03-09-2006, 07:10 PM
