586,042 active members*
3,577 visitors online*
Results 1 to 10 of 10
    May 2011
    29
    nexus 510c alarms
    started machine up this morning and had a few different alarms first 2 was,
    10 detector malfunction
    2 emergency stop
    hit reset and got
    72 servo warning
    82spindle warning
    power off and power back on and got 2 new alarms
    12 absolute postion warning
    31 servo malfuction
    been waiting to here back from mazak.
    thought someboby may have an idea.
    thanks, chris
    Dec 2008
    239
    For 31 servo malfunction please see the main Switch gear for servo is on or not because Since the electromagnetic switch OFF, command for the motor and servo system
    has been issued by activation of the emergency stop or door interlock function
    under CE machine specifications, the electromagnetic switches did not turn off
    within the required time. Also check the Drive Status healthy or Not.
    12 absolute postion warning= for this see the Encoder/Pulse coder , Feed back cable and drive
    for any other help please free to communicate on [email protected]
    Jul 2007
    284
    It would help if you could get the alarm number that is flashing on the drives. This will help to narrow down the exact alarm that is causing the problem.
    May 2011
    29
    NOT SURE IF THIS IS WHAT YOU WANT
    YZ= F3 9F F2
    ATC = AL 01 N1 01 ( I BELIVE IT IS A "N" IT LOOKS LIKE UPSIDE DOWN U)
    MAG= AL 01 N1 01
    Jul 2007
    284
    The battery for the servo system that backs up the absolute position is getting low. 9f is a warning for that. Look for a unit called MDS-A-BT#. It will need to be replaced.
    The alarms you see on the ATC and MAG drives are normal. Until they receive a command to move they will display this alarm.
    May 2011
    29
    THANKS FOR THE HELP TALKED WITH MAZAK LATE YESTERDAY AND THEY TOLD ME THE SAME THING.
    I DIDN'T UNDERSTAND THEM CLEARLY BUT THINK THEY SAID WILL HAVE TO RESET MY HOME. IS THAT CORRET?
    GONING TO WAIT TILL THE BATTERY COMES IN AND CALL THEM BACK IF NEEDED.
    Jul 2007
    284
    Yes you will have to reset the home position. If I remember correctly it should be as easy as putting the machine in zero return mode and sending it home. Because all Mazak's have dog switches it should be pretty automatic (compared to other machines).
    May 2011
    29
    WILL I NEED TO HAVE MACHINE TURN ON OR OFF TO REPLACE BATTERY
    Dec 2008
    239
    Quote Originally Posted by CLATHAM View Post
    Machine should be ON
    May 2011
    29
    THANKS FOR ALL THE HELP. HAVE HAD ALOT OF HELP WITH THIS FORUM NOW AND IN THE PAST
  1. Measuring Probe Nexus 510C
    By Nine Blue in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-06-2015, 12:13 PM
  2. Mazak Nexus 510C II Probing
    By KTPDAN in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-28-2011, 07:29 PM
  3. LOOKING FOR NEW HIGH QUALITY VMC IN NEXUS 510C CLASS
    By rmhydro in forum Uncategorised MetalWorking Machines
    Last Post: 12-21-2010, 03:20 AM
  4. Nexus 510c manuals
    By inioxos in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-02-2010, 10:23 PM
  5. New 510C-II
    By paptep in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-15-2008, 08:27 PM
