586,801 active members*
6,448 visitors online*
Results 1 to 6 of 6
    Aug 2008
    303
    What size gear belts for stepper gear reducer?
    I'm in the process of designing the main drives for my plasma table, and I'm not quite sure what size belts I should use for the gear reducer.
    The table will be 5X5, and I'm using 16 pitch 3/4 wide rack and pinion. I need to make a 3:1 gear reducer to go in between the stepper motor and drive pinion using a gear belt.
    I'm looking at using XL belts and sprockets, but I'm concerned that the 3/8 width of the belt will not be sufficient.
    I was really wanting to use a belt about 3/4 wide, but that is only available in an "L" belt, and that would make my sprockets too large.
    Thanks for any info.
    Dan
    Aug 2008
    303
    Anybody ??
    How wide are your reduction belts??
    3/8 ??
    3/4 ??
    Jan 2011
    I can't help any, but I am watching for an answer, since I'm planning on building belt reductions for my plasma table. I've been planning on using 3/8" XL belts since I've seen others using them, but if there's a better option I'm open.
    Carl
    Aug 2008
    303
    I was searching my "junk" pile, and found 5 brand new 170xl belts !! Now that I've actually held one in my hand, I think they will be fine. The sprockets for the XL belts are a way cheaper than the larger "L" size also.
    I needed a 3:1 ratio, so I ordered three 16-tooth, and three 48-tooth sprockets.
    Dan
    Jan 2011
    Would you mind sharing what you bought and where? (since 3:1 is exactly what I was planning as well)
    Carl
    Aug 2008
    303
    I live in Canada, so I don't have near as many places to buy this stuff as you would.
    The part numbers are the same though;
    small gear-Part# 16XLB037
    large gear-Part# 48XLB037
    Google those numbers if you want pics.
    Dan
  1. Gear Size/Ratio
    By MPSC in forum EMCO Lathe
    Last Post: 06-19-2013, 04:56 PM
  2. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum Uncategorised CAM Discussion
    Last Post: 04-05-2012, 03:55 PM
  3. Need a Lagun Lathe Gear or Custom Gear Maker
    By douglasco in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2011, 03:54 PM
  4. Drawbar gear not the corect size.
    By AccuMillGuy in forum Uncategorised MetalWorking Machines
    Last Post: 03-29-2009, 05:14 PM
  5. Do I have to use timing belts or gear box?
    By Chivo in forum Linear and Rotary Motion
    Last Post: 09-28-2005, 08:41 PM
