I would like to add a CNC mill to my shop I have a small marine products business and I have a few things I would like to build from aluminum. I have a Shopbot CNC router that I make a lot of parts out of HDPE & UHMW plastic. The router could cut some aluminum but it would be slow and since I have a MDF vacuum table on the router the use of coolant would not work.
I have a few questions what options are a good buy and what would be better to pass on. The vise they list seems expensive when I believe I could get a Kurt for that money as an example. I have a fourth axis for my router table I have never used I am thinking I might be able to use it with the Tormach it has a stepper motor. I am sure I could order the driver for the fourth axis.
I plan to do prototyping and small runs of parts. I was watching the video on the tool setting and it seems pretty fast compared to the routine I go through with my router. I don't think I want to spend the extra money on the tool changer but that would be a nice option. Are you guys happy with the performance of your Tormach? You can send me a PM if you would rather not post on here.
I have a Wells Index Manual mill it is a little bigger than a Bridgeport I have thought about converting it but I need to make parts not work on a machine. I do not have room for a large machine and do not have the electric service to run more than a 4 or 5 HP motor. I only have 100 amp service to the shop and I need to run other machines. All the machine centers I find used have huge motors on them and they are too big for the space I have for the machine. I have a couple manual lathes as well. I would like to end up with a small CNC lathe eventually as well. I may have to get rid of one of my lathes to add a CNC lathe but that is another decision for another time. I want to get into a CNC Mill for now.
Let me know what you think.
Mike
