586,108 active members*
3,218 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > Roboform 400 with c axis 128 amp schematics needed!
    Nov 2006
    382
    Question Roboform 400 with c axis 128 amp schematics needed!
    I have a Roboform 400 with 128 amps and a c axis. Use to have a tool changer. I am needing schematics for this machine! I have a bad relay or something showing up like a short from the head to the table. My c axis has either a bad cable or an encoder head and has no idea where it is at or where home is at. I need a schematic so bad I can taste it. Before you ask Charmille says they dont have them. They will send down a board swapper to fix the problem. Before I do that I want to know what the problem is and just have them send me the bad board or me replace the component that is bad. 317-408-2684 cell or pm me. HELP HELP HELP!
    Jetski (alias Tooling and Engineering Czar)
    "I may not have the keys to success.. but I have learned to pick the locks"
    Nov 2006
    382
    Come on... Someone has to be able to track down a schematic for a Charmilles? I have a big non working expensive room divider here if I can not get it to run! I have a big boat but don't need an anchor this big?
    Sep 2011
    Jetski
    Here are some pics ,Dont know if its any use to you looks to be in russian
    Bernie
    Charmilles Roboform 400 | MachineParts.ru
    Edit ; Just thought about this forum might be something
    http://www.edmcorner.com/
  1. Hardinge CHNC Schematics Needed
    By JimBoyce in forum Hardinge Lathes
    Last Post: 06-10-2014, 12:55 PM
  2. schematics for a Roboform 400
    By jetski in forum EDM Discussion General Topics
    Last Post: 10-19-2010, 01:22 AM
  3. Schematics needed for QT-15-U
    By RPM1975 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-04-2010, 03:38 PM
  4. just bought a roboform 400 with c axis
    Last Post: 03-28-2009, 09:40 PM
  5. schematics needed
    By atorick in forum Fanuc
    Last Post: 08-02-2007, 10:17 PM
