I guys does anyone have the manual or the tips on how to work with the tables of a Toyoda FH80 with fanuc 15M14.
Thank's
José Mário
Thank's
José Mário
pm me your name and contact information, i work for yamazen which is the toyoda distributor of new machines.
Thanks for the disponibility DANTEATER, but i have already found the code for the table movement. If i encounter another problem without solution i will contact you.
Thanks again
using MDI operation.
press mdi,program,mcode,eob,input,start.
automatic changer M90; start.
toyoda FH80B,table not automatic function.pls u check sensor table ready(E3S-2B41). position(pos L/R) actived or not,check table clamp unclamp pressure.
thank's
