586,072 active members*
4,681 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Source for 8mm od x 2mm wall nylon tubing.
Results 1 to 10 of 10
    Oct 2003
    530
    I need to replace two grease lube lines on my Okuma MCV4020. There 8mm od x 2mm wall nylon tubing. I can't find it anywhere in 2mm wall only 1mm wall. Anyone know where to find 8mm x 2mm wall tubing?
    Thanks in advance :cheers:
    May 2004
    4519
    What length? Does it have to be nylon? What actual pressure? Why won't 1 mm work?
    Oct 2003
    530
    Length is about 10-15ft for each line. I don't know the exact length because I didn't remove the lines yet. I'm hoping to use the old ones like a fish tape.
    8mm od x 2mm wall nylon tube is what the machine came with. I want to find the original stuff if I can otherwise I'll probably have to use the 1mm wall tube.
    Don't know the actual pressure, the lines are grease lube lines for the z ballscrew and atc cam box. They are lubed with a hand operated grease gun.
    May 2004
    4519
    Ok. Thanks. I will investigate this further.
    Jul 2005
    12177
    5/16" by 1/16" wall acceptable?
    Top of the table on this page.
    http://www.slpinc.cc/stock/nylaflow%20pg1.pdf
    You might have to buy 250'.
    Oct 2003
    530
    That's the closest one yet! :cheers:
    250 feet would be ok as long as the price isn't 10 bux a foot. Okuma want's almost that for a foot and I planned to buy around 50 feet. 500 bux for nylon tube
    May 2004
    4519
    Sorry. I guess something happened here.
    Oct 2003
    530
    Quote Originally Posted by txcncman View Post
    PS: I did all that with about 15 minutes of web searching (8mm od tubing)
    What do you mean by that?
    I found every other size under the sun except the size that came on the machine. I spent a lot more than 15 min looking on the internet and talking with local vendors. Don't think for a minute I didn't do my homework before asking for help here.
    Nov 2011
    8mm OD/6mm ID SSG in UK ...
    SSG are one of the UK's leading nylon tubing suppliers and can supply almost any size of Polyurethane and Nylon tube ... if it's not on their website, they can normally get it for you within a few days.
    8mm can be found here -> Nylon tube 8mm
    Regards
    Roy
    Oct 2003
    530
    Update, I found some 8mm od x 5mm id tubing from Devco. I orded it and some compression sleeves. Everybody I talked to said the compression sleeves are all the same. We installed the new tube and the compression sleeves. The z axis ballscrew tube worked fine, but the length of the tube was too long on the ATC cam box and the tube burst while purging it. The compression sleeves also were leaking.
    I ended up biting the bullet and ordered the 8mm od x 4mm id tubing from Okuma. I ordered the compression sleeves too, but they were the same ones that leaked from Devco.
    I was just about to order new fittings when I noticed they were made by smc. A quick call to them got us the correct compression sleeves.
    Everything is working again. :banana: :banana: :banana:
  1. What is the best way to cut thin wall brass tubing?
    By lerman in forum MetalWork Discussion
    Last Post: 08-11-2015, 03:47 AM
  2. Wall thickness for threaded tubing
    By Rockwall in forum Mechanical Calculations/Engineering Design
    Last Post: 07-19-2009, 07:09 PM
  3. T304 Stainless .065 wall tubing
    By l u k e in forum Welding Brazing Soldering Sealing
    Last Post: 06-05-2009, 09:46 PM
  4. milling thin wall brass tubing
    By jackie_burton@m in forum Material Machining Solutions
    Last Post: 09-29-2008, 09:46 PM
  5. Steel rectangular/square tubing wall thickness
    By pstockley in forum MetalWork Discussion
    Last Post: 01-27-2006, 08:56 PM
