I have been trying to repair this machine (CNC lathe LB9 OSP500L-G)and hope someone can help me with these:
1) There is no display on the monitor when the machine's main breaker is
switched ON
The Control ON/Reset switch when pressed lights up with the NC status lamps and then all trips OFF. On tripping OFF, the OPUS 500 unit(CPU rack) shows 3 lamps on ON state; i) under voltage ii) +24V iii)+12V
If CPU power supply module is removed from its "connector slot" and the main breaker switched ON, the Control ON/Reset switch lamp lights up when pressed.No alarm lamps light up on the CPU rack but +5VDC,+12VDC and +24VDC are measured on the power supply unit with the multimeter.
2) None of LED's on the VAC III spindle drive unit are ON.
The voltages measured between the inputs of 3P lines to the spindle drive unit are 200V AC.The labeling on the 3 phase lines are: R2B,S2B and T2B.
The output lines to VAC motor (labelled U1,V1 and W1) measured zero between phases and 3.5V AC when measured to ground.
On the spindle drive Control PCB, CN7 connector pins 1 and 3 measured 7.5V AC and connector pins 2 and 3 measured zero volts .As the measured voltages are not 19V AC the manual states to replace power supply unit.
I have not found this power supply unit yet so I have decided to post this thread for feedback. Im a fitter machinist with CNC programing and machining experience and studying mechatronics.
Please any help on troubleshooting the above mentioned problems will be greatly appreciated. Thank you
