586,500 active members*
1,860 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Need suggestion for Taig lathe DC motor
    Jun 2009
    231
    I have a used Taig lathe coming soon and am very excited. It has a single phase 1550 AC motor with it now (not the Taig OEM) and would like the ability to control the speed. I plan on modifying it to have Mach 3 sense the speed and, of course, CNC the unit in time.
    Any suggestions on the size and type of DC motor to look for?
    I've seen a lot of people finding and using tread mill motors. If I locate an old treadmill do I need the controller with it or just the motor???
    www.digitalPimple.com
    24223
    If you want variable speed you need a controller, KB Baldor SCR or PWM drive, for fixed speed a full wave bridge across the 120vac.
    Al.
    Albert E.
    Jun 2009
    231
    Al.
    Thanks. I can design and build a PWM so I guess I will start looking for a used treadmill in my area this week.
    Thanks for the info.
    What WATTAGE do the majority recommend or use for the Taig??
    Is there any reason to have a speed greater then 1550 RPM??
    New to metal working.
    24223
    Most of the Treadmill motors claim >2hp but I think that is a little over rated.
    If you are lucky, you may find a T.M. with a Leeson with a 3hp 4000rpm.
    Nice motors.
    Al.
    Albert E.
  1. Suggestion on CNC lathe
    By Jim Anderson in forum Benchtop Machines
    Last Post: 03-24-2011, 05:56 PM
  2. Mini Metal CNC lathe suggestion
    By Athaya in forum Want To Buy...Need help!
    Last Post: 02-08-2011, 07:44 AM
  3. Need suggestion what software or cam or ??? to use with lathe/turntable
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 02-06-2009, 07:49 AM
  4. Looking for router motor suggestion for photo engaving
    By GlacialWanderer in forum DIY CNC Router Table Machines
    Last Post: 07-06-2008, 09:17 PM
  5. Taig lathe motor
    By kong in forum Mini Lathe
    Last Post: 07-06-2007, 01:45 PM
