586,096 active members*
3,012 visitors online*
    Sep 2009
    7
    Helitronic Power HMC 400
    Hello everybody,
    We have a problem with HMC 400, the problem begins when we change of place and was left without power, and shows a error says 'CMOS checksum error-defaluts loades CMOS battery fail', we change the battery and the error disappeared, but now wen try to load main code now appears Illegal Op code in object file.
    Does someone knows the CMOs configurations for the MMI and MAIN cpu's or someone has the HMC 400 Technical Handbook?
    Best Regards
    Jan 2007
    103
    cmos
    it appears you have lost some settings with the battery/power loss.
    you will have to call to United grinding and ask for the instructions to reload the settings.
    you can find the contact info at Grinding.com: Your #1 Source for CNC Grinding Solutions - Grinding.com
    Good luck!
  1. controller power supply 115/230v OK for Australian power?
    By Momill in forum Australia, New Zealand Club House
    Last Post: 07-07-2011, 05:06 PM
  2. Helitronic 45 with HMC300
    By 94suptt in forum Toolgrinding / Toolgrinding Machines
    Last Post: 10-25-2010, 09:17 AM
  3. Replies: 5
    Last Post: 10-13-2010, 03:28 PM
  4. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
