586,119 active members*
3,607 visitors online*
    Oct 2005
    Flow Waterjet
    Update! Just had to replace the HP manifold on our Flow International Waterjet, anyone else had these problems?
    Oct 2005
    So, at 1000 hrs. we are once again stopped. This time from an ill fitting filter cartridge. The response from Flow is that there is no vendor problem, yet with their standards we pump gallons of water out of the system. Oh, by the way, we've had seals on our high pressure gage blow for the second time, so I've had to run by ear and guess at the pressure.
    Anybody else having these problems?
    You might want to try the waterjet yahoo group. It's pretty active.
    -Jeff
    Oct 2005
    105
    First try the waterjet group at yahoo.
    http://finance.groups.yahoo.com/group/waterjets/
    Have you tried any third party parts to see if they last any longer?
    Accustream
    IWP
    What modle Flow machine do you have?
    Aug 2005
    70
    Flow_Ken
    Where are you located? If it is cold in the shop in winter after a shutdown, this can cause seals & other parts to fail prematurly as the pump builds heat too fast when the parts are cold. When you replace seals, fire up the pump & slowly build up pressure @ 15 minute intervals. Just a thought, Tom
