After much checking of the plumbing, it seems the Z ballscrew of my nm135 is not serviced by an oiler line.
Odd, because all 6 millways and the X and Y ballscrews all have oil lines.
Anyhoo... I guess I never noticed the Z ballscrew non-oiling because often I manually oil in liberal quantities. But now that the machine is in its full enclosure, it is difficult to access the Z ballscrew.
So.... what kind of lube should I use on the Z ballscrew? Grease? Oil? Ideally it would be a lube that can last, say, 50 hours of operation before needing re-lube.
