586,113 active members*
3,594 visitors online*
    Oct 2011
    EZ TRAK SOFTWARE HELP
    Hello just purchased a 1998 Bridgeport ez trak BPCZM used mill, wired it up cut power on everthing seam to come up ok, (we have never used ez trak before) homed everthing ok started to try some manual test runs and noticed the descriptions on the keys on the monitur do not come up everything works ok by looking up the keys in manual, pics below, we try to start up the machine with the floppy disc installed and it goes to the energy screen and says del flashing f4 then screen goes black and just sits there wont do anything till i reboot without the disc I tries a differnt floppy drive same problem I tried the floppy disc in my laptop it want to change my laptop over to eztrac so its seams to be working ok, can anyone help with this problem.
    this is a pic off the net of what is should look like
    Nov 2004
    3028
    What does BPCZM stand for?
    A EZTRAK from 1998 should boot from the hard drive.
    You may need to check the CMOS settings as they may have gone to default. If so there is no guarantee if it will boot correctly (read the hard drive or floppy correctly).
    Or it may have corrupted software. Best advice for long term reliability would be to get a DOM preloaded with software from EMI-inc.net
    If the CMOS battery is dead, it has to be replaced. Probably is a Ni-Cad and if it leaks will kill your mother board. It is soldered on. Then CMOS set.
    Search this forum. This is a very common issue.
    George
    Feb 2005
    154
    EZtrak display
    I noticed that the display is showing only three decimal places. That would indicate that it is in the metric mode. I have heard that you shouldn't shut these machines down in the metric mode. Try switching back to inch mode then reboot??? Maybe George can tell us if this is a possible solution....
    Pete
    Oct 2011
    No luck
    Pic below of where I got the bpc2m it is on the keyboard I am not sure what it stands for, we rebooted with standard number setting, no luck did not bring up key descriptions on monitor, I looked at the battery no sign of leakage, mill was purchased as rebuilt no telling if this was replaced I will order replacement, anyone else have any ideas greatly appreciated, thanks for the help.
  1. EZ-Trak SX Software
    By nippy7 in forum Bridgeport / Hardinge Mills
    Last Post: 11-04-2020, 08:32 PM
  2. EZ-TRAK software
    By fuzz in forum Bridgeport / Hardinge Mills
    Last Post: 05-10-2010, 05:10 PM
  3. EZ TRAK DX Harddrive and software series I
    By c3controls1 in forum Bridgeport / Hardinge Mills
    Last Post: 03-24-2010, 12:03 AM
  4. EZ-Trak DX2 ver3.8 software
    By Sky-high-11 in forum Bridgeport / Hardinge Mills
    Last Post: 04-23-2009, 06:54 AM
  5. Need software for EZ-TRAK PLUS
    By fourthgenss in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2008, 09:51 PM
