586,110 active members*
3,249 visitors online*
    Apr 2005
    108
    Fanuc motor numbering
    my motor number is A06B-0127-B077
    I got offer for A06B-0127-B577
    could someone explain me the diffrence
    and the last 4 number what it mean
    24221
    Same motor/encoder except B577 has taper shaft.
    Al.
    Albert E.
    Jun 2010
    161
    Actually, with this particular motor, the standard shaft is taper. Here is the decoding for this one. It does not apply to all FANUC alpha servo motors.
    A06B-0127-Bxyy
    X : 0 (taper shaft -- standard)
    X : 1 (tapers shaft with brake)
    X : 5 (straight shaft)
    X : 6 (straight shaft with brake)
    YY: 75 (pulse coder alpha A64)
    YY: 77 (pulse coder alpha I64)
    YY: 88 (pulse coder alpha A 1000)
    Note: There is often a suffix after the the -Bxyy which can call for straight shaft with key, IP67, special bearings, etc. Too many to list.
    Apr 2005
    108
    thank you very much for the help
    24221
    Al.
    For some reason I read it backwards.:devious:
    Al.
    Albert E.
  1. Numbering program lines
    By tz1238 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-24-2011, 12:26 PM
  2. Numbering 88hs tools
    By Ryanscustom in forum Fadal
    Last Post: 08-13-2011, 02:07 AM
  3. macro for serial numbering?
    By Mark Pelnar in forum Okuma
    Last Post: 05-07-2011, 10:41 AM
  4. Tool Numbering, What's Your Method?
    By David Bord in forum Tormach Personal CNC Mill
    Last Post: 03-08-2011, 11:20 PM
  5. line numbering
    By xairflyer in forum G-Code Programing
    Last Post: 05-10-2005, 08:22 PM
