586,217 active members*
3,359 visitors online*
    Apr 2009
    12
    971 Failed to load
    I have seen another thread asking about this, but it did not have a real answer to it. Getting the machine warm has not helped the problem. It also says drivers not loaded. Could sure use some help or ideas on this one, it will not communicate with the floppy drive, USB, or the rs232 port. I have never setup the Ethernet on it. Again thanks for any help or Ideas.
    Aug 2011
    Here is some troubleshooting information for that alarm:
    The 971 Alarm (DRIVERS FAILED TO LOAD) is a time out alarm at power up generated by the Main software when it did not detect the presence of the Enet card in about 30seconds after the main software fully loaded.
    Can be cause if the mill code (FV) version is corrupted
    Can also be generated if you cycle the power on the machine to Fast.
    Turn off machine and wait 5 seconds before powering back on.
    Verify Supply Voltage to E-net card should be at least 4.75vdc, with the card
    connected.
    Verify that Data & address buss to the PC104 are well seated.
    Check ribbon cable connection from HD to PC104 PCB, reseat if possible
    Remove all connections to the E-net card, USB cable, Rs-232, & E-net cable: cycle power
    Contact your local HFO if everything else fails.
    Apr 2009
    12
    I will give these a try.
  1. Failed to Boot Win NT !
    By mte.jalal in forum Cincinnati CNC
    Last Post: 12-12-2010, 08:55 PM
  2. 4 and 5 axis= failed efforts.
    By themuffinman in forum Mastercam
    Last Post: 09-03-2010, 09:22 AM
  3. Ultimax3 Disk Failed
    By musnar in forum HURCO
    Last Post: 07-06-2008, 06:59 PM
  4. Tried to buy a HF X2 yesterday. Failed!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 03-12-2008, 12:00 AM
  5. Failed transformers?
    By Jetlag in forum CNC Machine Related Electronics
    Last Post: 09-09-2005, 08:50 PM
