Hi Guys,
Thought I'd share with you my new Y&Z axis design, I've ordered the bits so should know some time next week if its a winner...
Anyway heres the details,
BOTH axes are rack & pinion drive, module 1 with a 30 tooth pinion.
Drive is from 4nm NEMA 34 stepper motors on both axes, currently its direct drive but i have allowed for the installation of 3:1 reduction via a planetary or belt rive gearbox.
The extrusion profile is bosh rexroth 40x120.
Hiwin 15mm Bearing rails.
Chassis folded 3mm Mild Steel.
Z axis is counter balanced with a variable force gas strut, to stop it falling.
This is intended for a large format. (10x5)
PS. I know your all going to say that ball screws are better for the z but I was trying to keep everything low profile and simple.
Anyway let me know your thoughts.
