586,106 active members*
3,140 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Having Trouble cutting with machine cutting correctly
Results 1 to 18 of 18
    Oct 2011
    Hey Guys,
    I'm trying to machine some small rectangular shaped pieces. They are a bronze alloy and are 1.370"L x .583"W x .500"H with a 9/64 radius. I'm using a Hyundai Kia VX-500 and a .500" 3 Flute Kennametal Endmill. My finish pass removes .030 at the full depth of .500" with 2 spring passes. I'm having trouble with the fitment of the radii of the parts. It's cutting the 1.370 and .583 to size correctly. If this makes sense, across diagonally of the part isn't the same. I'm measuring 1.407 across one side and 1.411 across the other side.
    I've also had this issue with cutting an octagon. In gibbs cam everything is symmetrical and the machine is cutting a non symmetrical part that varies anywhere from .003 to .010.
    Does anyone know what this could be caused by?
    Jan 2007
    1389
    Have you checked backlash?
    Oct 2011
    Quote Originally Posted by Delw View Post
    Nope..Haven't thought about it with this machine only be 2 years old and very few hours. How can I check it?
    Mar 2006
    2712
    Back in the old days we called that axis reversal error.LOL
    Dick Z
    DZASTR
    May 2004
    4519
    Quote Originally Posted by ztimbo View Post
    Do you know what backlash is?
    May 2004
    4519
    Oct 2011
    Quote Originally Posted by txcncman View Post
    yes, i know what backlash is. I didn't think it was a problem with CNC's nowadays.
    May 2004
    4519
    Ok. Yes, backlash is always a problem in mechanical movement. If you know what backlash is, then you should know how to check it. You mount a dial indicator on the spindle so that it touches a solid point on the table. Then you move the axis over to load the indicator and move to zero. Then move the axis back the opposite direction at the smallest resolution and count the detents to find the amount of backlash. Then you can go into the parameters and adjust the backlash for that axis. Then repeat for the other axis.
    Oct 2011
    hmmm, sounds simple enough...I've only been using a cnc for the last 2 years so im kinda new to all this. All ive ever done has been conventional mill and lathe stuff. I was just under the impression that backlash didn't occur with cnc's due to the ball screws.
    I also understand that backlash occurs in all mechanical movement if you get right down to it, but I'm talking about a substantial amount here, around .010". I just didn't think cnc's got that kinda of backlash
    Jan 2007
    1389
    acording to you first post its only .004 which is .002 perside thats a far cry from .010
    how are you checking the part calipers? Mic? toss that calipers in the garbage if you are and use a more accurate way of checking the part.
    also look for taper on the flats, burrs etc.
    Oct 2011
    I will not toss my calipers in the garbage. I can measure within .001 all day everyday with them.
    I'm using a mic to check this tho, and please re-read my first post and you will see where I was talking about cutting the octagon.
    Jan 2007
    1389
    can you show a picture of the part?
    BTW anyone can measure .001 with calipers, all day but its not correct trust me.
    I saw the part about an octagon does it measure the same across each flat on the same part?
    if not more than likely backlash or drives need to be tuned
    Mar 2006
    2712
    I'd be willing to bet a few beers that txcncman is right, backlash is probably your problem. Did you read any of those links?
    Worst case I saw was a ball screw support became loose and rocked back and forth even though it was doweled in position. Another was a rotary axis "zero backlash" split gear that slipped into "lotsa backlash".LOL
    Dick Z
    DZASTR
    May 2004
    4519
    I am actually going to disagree with this, with some caveats. A well trained and experienced machinist can measure very accurately and consistently with dial calipers when they use gage blocks or other standards to verify the caliper readings. I have frequently measured parts with calipers while on the machine and then verified within one or two ten thousandths on a CMM off the machine. Just because a micrometer is more precise does not mean it is always more accurate.
    This is not something I would put any faith in a novice to do.
    Jan 2007
    1389
    so your wasteing time by takeing 3-4 steps to do one step with a micrometer?
    why go through the hassle of doubting yourself and double checking with mics later on do it correct the first time with a mic. saves time which is money.
    there is a reason for quality control. theres also a reason why all parts should be check with 2 different pcs of equipment shop flor and inspection room. 1st articles etc etc.
    the problem is alot 1-5 man shops dont Follow this practice/procedure and thats why there is quality problem.
    I have 4 people working here me myself and I and my wife.
    I always check all parts then have here double check NOT with the same tools but actual inspection tools that get calibrated.
    unless we both end up with a dylexic moment theres never a problem to print.
    one of my biggest pet peeves on this forum and outside processing is "well isnt close enough" or people suggesting useing different materials thats NOT called out on the print because it machines easier.
    sorry if its not to print its garbage there is NO close enough except in china.
    most if not all parts should run exactly at the mean size. granted we have tolorances but theres really no reason in most parts needed to use all of it. with some exceptions (dont get me wrong there are parts that will eat lots of tols but usually in nickle alloys and big rings with lots of contours.)
    Delw
    May 2004
    4519
    Delw
    Ok. I will sit here and watch you use your 48" micrometer to measure the center to center distance between 2 holes and hold + / - 0.001 on the location on a compressor mounting frame while is is still on the boring mill.
    Then right after that I will watch you use your 72" micrometer to measure the male register of a lift pump housing and hold +0.000 / -0.003 on size and circularity while it sits on that boring mill over there.
    Don't get too bent out of shape over how other people run their quality systems. If yours is so much better, soon you will be the only shop left in business.
    LOL
    Jan 2007
    1389
    WOW you have incredible skills if your using calipers for such a thing you got lucky or let close ones go by.
    I would generaly use a muller bar and a set of starett gage blocks.
    your completely missing the point, and NO I would never use calipers to measure a +-.001 tolorance especially on something that long.
    Oct 2011
    I'm having a service tech come out and check everything on the machine. So we shall see what he finds wrong, if anything.
  1. Replies: 3
    Last Post: 09-19-2010, 02:40 PM
  2. Replies: 0
    Last Post: 09-17-2010, 09:09 AM
  3. Replies: 0
    Last Post: 09-17-2010, 08:51 AM
  4. Newbie needs help! cutting acrylic, and double cutting? 3040 machine
    By stephaniehamer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-29-2009, 09:37 PM
  5. I need help about cutting heads which apply to apparel pattern cutting machine
    By sheepgrass in forum Mechanical Calculations/Engineering Design
    Last Post: 05-12-2006, 07:09 PM
