586,388 active members*
3,267 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Sep 2011
    5
    CNC Machine ts-3040c-h80
    Hello every one.
    I am new in this forum, and I need some help.
    I get a new cnc machine ts-3040c-h80 yesterday, but I can not get it
    work, I am using a IBM Thinkpad T51 and running mach 3, but I have tried
    to set port and pins as it is shown in the manual, but nothing happens.
    Do some one have this machine and how have you set up the port and pins?
    Maybe the IBM can give enough power?
    Please help!
    Yours sincerely
    Kjeld Ottsen
    Nov 2011
    i have the same problem
    have you solve it?
    if yes how?
    Feb 2012
    Hey
    I also bought this mashine, and got problems.
    When i received it, i found that the pcb mounted at the parallel port had a short. Due to bad ingineering.
    The seller ( Amonstar Inc ) send me a replecement board, and now the box
    powers up. ( Fan is running, and the led's at the driverboards are on ).
    When i install Mach3, and runs it out of the box, i can get it moving, but in
    one direction only. It sounds like it's trying to move the z-direction further
    down at the same time.
    When i follow the instructions in the manual, and setup the pins, the same
    happens.
    Then i install the configuration files from the manufacturer, i get into deeper s...
    In Mach3, the resetbutton gets green, somtimes gray, and the text in it dissapeers. When i turn the machine on, i cant move anything.
    I have given up on Amonstar, communicating with them is mostly 'black talk', just like the manual. Its a disaster.
    Sep 2011
    5
    Hello Karsten
    I got a file from another user, and this solve my problem and it is running very fine now.
    Kjeld
    Sep 2011
    5
    PM mail sendt til dig ;-)
    Dec 2010
    TS 3040C
    Hello,
    I am considerring to buy the same machine. I am makin small articles from wood e.g. jewelery boxes, vehicle models, toys etc.
    is this machine suitable for that sort of work or is it to small?
    John L
    Apr 2012
    TS-3040C-H80 configuration file
    Dear friends,
    Anyone have a good configuration file for TS-3040C-H80?
    I am new...
    Best Regards
    Luis
    Apr 2012
    Quote Originally Posted by ottsen View Post
    Hello Karsten
    Kjeld
    Dear friend,
    Do you have a good configuration file for TS-3040C-H80?
    I am new...
    Best Regards
    Luis
    Sep 2011
    5
    File for cnc ts-3040
    Here is the file for this cnc machine.
    TS-3040C backup settings for mach3mill.rar
    Quote Originally Posted by lleal View Post
    Dear friends,
    I am new...
    Best Regards
    Luis
    Apr 2012
    Dear ottsen,
    Thank you for the file.
    Have you installed home and limit switchs? Have you pictures about the locals?
    Have you used closed sw's for the limits and open sw's for the home?
    Best Regards
    lleal
    Jun 2012
    bonjour à tous
    j'ai le meme probleme, mais avec l'axe X qui marche que dans un seul sens
    axes y et z ok
    Pouvez vous m'aider ? merci
    Sep 2010
    Did you get it working?
    I initially could not reset the machile until I swapped the EMERGENCY STOP input to active LOW----then I had control.
    I have just received my machine------it was not fully assembled so I had to put the cables on the Servo motors etc. Also the base bracket was bent, and some screws loose. I have fixed it all but my base table is not parallel with the X/Y movement of the gantry. It is about 1-2 m higher on one side. I don't know if the original bent bracket caused this, but in any case it needs to be fixed before I can do any proper milling/engraving
    Does anyone know if the base table-gantry alignment can be adjusted mechanically? If not, is there a way I can add the correction to Mach3? Or make a G code correction or something?
    Dec 2012
    Question TS-3040C-H80
    Hi
    i have just bought this machine recently through some one. i cannot manouver the software mach3. is there any one who can help. how do i change values of z? is it used for character engraving any way? is there any one with the manual to help me please?
    thank you so much
    Dec 2012
    Post
    is it possible to send me a manual for this machine so that i can peruse through also? thank you
    Jun 2011
    24
    Hi I have bought one of these machines and OMG!!!! the chinese to english translation is awful
    Has anyone got theres up and running fine? if so, can you send me a copy of your mach3 settings profile please. I see one has been uploaded in this post, has anyone else had the same problems and have tried this file? was it ok?
    Jun 2013
    I am new also, I have purchased a Dongda TS-3040 early this year and to this day I still cant get it going!!!
    I purchased a new PCI card hoping that was the issue but it wasn't. I have been in touch with Amonstar and they have sent me some more instructions and settings - still no go!!!
    I have got the machine to a point where it turns on the spindle and thats it, can't turn it off, can't adjust speed. I have also tried to run some of the Wizards loaded programs to see if theres any communication between the PC and the CNC, still no success... has anyone experienced these issues?
    I have a 15 year old Multicam machine with ancient software and considering that technology progresses rapidly and easier to use, I find you need a diploma to use this MC and its software.... must be that I'm ancient also!
    Sep 2011
    5
    Hi
    Pleace send me a personal mail on Ottsen#gmail.com(change the # with @) and I will send a file for you,
    this file helps me and my machine is running fine.
    Ottsen
    Dec 2013
    Dear All
    I bought this machine also from Ebay. I have set it up as per the manual. When I turn the machine on the stepper motors judder. I have down loaded the .rar file from this thread but have no idea how to set up Mach 3 to read or use it.
    Help!!!
    Jun 2011
    24
    Hi
    I setup a sticky at the top of the chinese cnc section, just use this file to configure your machine, it works perfect, it even puts the X and Y axis around the right way but you can swap these around if you'd prefer, i would think the judder is the head movement is too fast, this file should sort it. Enjoy :-)
    http://www.cnczone.com/forums/chines...y_swapped.html
    Mar 2014
    Hi, I am also new here and with hoby-cnc-machining.
    I also bought this type of a machine. Have installed Mach3 on my old pc with integrated parallel port, WinXP, x32... with PC, I hope, is everything OK
    So the problem is this:
    Most of the time movement in all directions is stumbling, it looks like it is intermitting(and slower), but sometimes the movement is good(speed good, smooth). To move good or bad it doesn`t depend in witch position machine is (wires are not broken at least(I hope)), thus I have read of interferences in wires..
    So what to do? what could cause such problem? I wrote a letter to a seller, he suggested to ground the machine which I did (to a radiator ), the stumbling is the same except for a little bit (very little bit) more of good movement.. And have noticed that I can feel of some electroshock when touching the machine..
    Once more, what should I do, any Ideas
    This is my machine and its problem:
    https://www.dropbox.com/sh/ab2txa7bxpmtrm9/er5cPn1lVZ
Page 1 of 2 12
  1. Sanven 3040C, It's ALIVE
    By dwindsor in forum Chinese Machines
    Last Post: 02-28-2014, 03:51 AM
  2. 3040C won't run
    By mreichle3760 in forum Community Club House
    Last Post: 01-24-2014, 06:09 PM
  3. TS 3040C-H80 brand new machine, can't get to move
    By ncls00 in forum Commercial CNC Wood Routers
    Last Post: 04-01-2013, 02:30 AM
  4. TS 3040C H80 SLOW!!! Feed rates
    By Macmaps in forum Australia, New Zealand Club House
    Last Post: 12-18-2012, 07:21 PM
  5. cnc engraving machine TS-3040C-H80
    By Victor_Baeza in forum Spanish
    Last Post: 12-10-2011, 04:08 PM
