586,069 active members*
3,689 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC O-T CONTROL LOST PARAMETERS
Results 1 to 17 of 17
    Feb 2010
    Angry FANUC O-T CONTROL LOST PARAMETERS
    HAD TO WIPE MEMORY DUE TO A 930 CPU INTERRUPT ALARM.DIDN'T HAVE ALL THE CORRECT PARAMETERS FOR THE MACHINE BECAUSE THE COMPANY THAT RETROFITTED IT IS OUT OF BUSINESS.IT IS AN AMERICAN LATHE 3220 WITH A FANUC O-T CONTROL.WE HAVE FANUC COMING DOWN TODAY OR MONDAY NOT SURE IF THEY CAN FIX IT BECAUSE WE DON'T KNOW EXACTLY WHAT OPTIONS WHERE ON IT.I THINK I HAVE ALL THE PARAMETERS EXCEPT THE OPTIONS.I JUST HOPE I AM NOT WASTING MONEY BY HAVING THEM COME AS THEY CHARGE $145.00 AN HOUR.DOES ANYONE KNOW IF THEY WILL BE ABLE TO FIX IT SINCE IT WAS A RETROFITTED MACHINE?WE REALLY NEED THIS MACHINE UP AND RUNNING SOON IT IS ONE OF THE MACHINE'S THAT IS BEHIND ON IT'S WORK.
    Dec 2008
    239
    Fanuc OT
    Please send the machine serial number , and the Machine tool builder name , If possible The mother Board number , Is it model A /B and the spindle drive is Analogue or Digital. i will do the help to made the machine run regards = [email protected]
    Feb 2010
    AMERICAN LATHE COMPANY UNITURN 3220WX120 MACHINE SERIAL NUMBER IS 80138-78. FANUC MAINBOARD NUMBER IS SERIAL NUMBER 3200008994.THE PERSON WHO RETROFITTEF THE MACHINE WAS Leinart Machine & Automation
    Address: 3941 Highway 411
    City: Madisonville
    State: Tennessee, US
    Zip Code: 37354
    Telephone: (423) 442-1002
    THEY ARE NO LONGER IN BUSINESS.
    THE SPINDLE DRIVE IS A SAFTRONICS DIGITAL DC DRIVE
    DCM6+/DCM12+
    Dec 2003
    24221
    Hindsight I know, but it is a 5min job to save all parameters, including 900's.
    A PM sent.
    Al.
    Attached Files Attached Files
    Albert E.
    Feb 2010
    We had fanuc come out today he worked all day on it got it going except for the x axis would not home out.Then at about 1:30 this afternoon we where at the machine and the screen just all of a sudden went haywire.Well he shut off the machine and started it up and then the 930 cpu interrupt alarm came back on and wouldn't start back up.He ordered another mainboard and a cable for x axis and will be back monday.Does anyone think the encoder for x may be out?Since it will not home out.or possibly a drive gone bad.
    Dec 2003
    24221
    What do you mean by not home, does it seek the home switch but not slow down when it hits it, or?
    Al.
    Albert E.
    Feb 2010
    the x will not zero out so that you can set it.so it doesn't know where it is at.
    Aug 2011
    2517
    there is a parameter for the maximum stroke (and thus the home position) of each axis. try checking that to see if its set correctly.
    May 2004
    4519
    @dodge - So, after spending over 14 hours on this experience with a machine still down, are you going to make sure all of the parameters on all your machines are backed up now?
    Just curious.
    Feb 2010
    thought about that last night and will tell the fanuc guy monday about the stroke setting.The machine we got the parameters from has a bigger x axis.still don't know why it keeps getting the 930 alarm unless there's a short somewhere.yes will definitely back up the payameters if we ever get it back running right again.
    Jun 2008
    1511
    Quote Originally Posted by txcncman View Post
    Just curious.
    So I am to assume that you are “that guy” who has never made a mistake???? I am starting to think that based on the relentless sarcasm that you give people when they ask how to fix a problem that they are having and you insist on offering advise of what they did wrong??
    Stevo
    Mar 2005
    816
    Yeah, I get that impression too, Stevo.
    Feb 2010
    We got it going but it still comes up with the 930 cpu interrupt alarm.It didn't come on for about 4 hours after he had it up yesterday.Will run it today and see how long it will stay up.The fanuc guy is coming back he said he would bring a power supply with him.That's the last thing left to try if that doesn't fix it he said it's probably a short somewhere.I think the drive's or the drive motor's maybe going bad also.When you are feeding the machine and crank the feed override control knob really fast it kills the machine giving a 416 x servo alarm.If you don't have the feed turned up it runs fine.The rapid and the feed are in the same knob.I have no separate control for the rapid.So i have 2 problems.
    Aug 2011
    2517
    possibly some of these.....
    Oct 2009
    297
    930 alarm
    930 means CPU interrupt alarm. The CPU is located in the master PCB.
    About the X home position you need to check the dec switch for that axis. Also, maybe a parameter for the stroke setting.
    Try (P and CAN) at power on and then home the axis. (P and CAN) at power on will neglect the parameters for the stroke so becareful when you home the axis.
    Jul 2019
    Need help. I need fanuc OT parameter list for SMG Strands S-5 turning center machine. No body is having similar machine in our city hence not able to run machine. Lost parameter list due to dry battery. Is there anyone can help me. Regards
  1. Lost fanuc 3T parameters
    By erikturn in forum Fanuc
    Last Post: 09-24-2014, 09:00 AM
  2. Siemens 810T 3-axis control lost parameters and plc
    By topcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-01-2010, 09:08 PM
  3. Fanuc O-M lost parameters
    By macperfo in forum Fanuc
    Last Post: 03-27-2009, 12:47 AM
  4. Parameters lost in Fanuc OM
    By wicked_won in forum CNC Machining Centers
    Last Post: 03-27-2008, 10:50 PM
  5. Replies: 2
    Last Post: 02-08-2008, 09:00 AM
